Results 1 to 7 of 7
Thread: Scale and Rising pH over Winter
    Hi,
    I really appreciate this forum and the pool calculatory. As a former chemistry major it was extremely intuitive to me.
    My troubles with my pool begin when I purchased our home 2.5 years ago. The pool was freshly replastered that year (2010) and winterized. I opened it to a high pH and some moderate scaling around the floor returns on the pool. I figured this was due to improper pool maintenance or issues with the new plaster. I found the BBB and installed a SWG that year and had an event-free summer. I opened the pool again last year with an off-the-charts high pH (despite closing it with it being around 7.5) but didn't notice any extensive scaling. In retrospect this was probably because I was not getting a particularly accurate CH estimate (either had a bum reagent or an expired test from my TF-100 kit) which was probably around 200.
    So long story short, I close the pool with the following numbers: pH 7.5, TA 60, CH 300, CYA 70. I open it again this year with a pH off the charts (at least 8.2) and further extensive scaling seems to have developed, mostly as a "ring" around the bottom of the pool (very similar to how a shower tub develops a ring). My current numbers otherwise suggest good closing chemistry (TA 60, CYA 40, CH 200) so I can't figure out what's happening. So my two major questions are:
    1) What are my options for scaling mitigation? I am aware of acid washing and the no drain compounds. Any strong opinions or success stories about either? What is a reasonable price to have a 20k gallon pool acid washed?
    2) What in the world can I do to prevent this pH creep over the winter? Why is this happening? I suspect there was a material used in the plastering that was probably not appropriate for a pool that's winterized. Otherwise my MA requirement is not awful during the year (~1-2 cups per week of MA).
    Thanks for all of your help and again appreciate this forum.
    frustratedpoolmom's Avatar
    SWSuburban Chicago, IL
    11,969
    Re: Scale and Rising pH over Winter
    You can try to keep the ph at 7.0 for about 2 weeks or so and brush daily with an appropriate plaster brush to try and dissolve. I would suggest a submersible pump mid winter (you don't mention if you freeze or not) to circulate, test and add acid (and FC if necessary) as required throughout the winter months. I would also lower the PH to 7.0-7.2 prior to close - and what chemical did you use to shock pool prior to close?
    I actually did not shock at closing. Just added the quat algecide.
    I actually would be a little challenged to test the water over the winter with the safety cover on and the water being a few feet below the skimmer!
    I'm in central Virginia so there is some freeze potential here for a few weeks of the year. More in a bad winter.
    Hey I have had the same issue...live in SE PA with SWG 30k pool and have had ph always rising needing to add MA all the time including winter....use a pump to circulate as suggested....how are you doing past few years? Any words of wisdom for me? Now I am dealing with high CH level...
    11,969
    Quote Originally Posted by Gaidal
    Not suggesting daily or even weekly, more like monthly. Pop one of the springs and stick the pump in there for a few hours is all.
    Thanks. Anyone have any particular recommendation for a cheap submersible pump I could chuck in there?
    11,969
    I would get a small one for under $100. You don't need much.
