Thread: How about a picture gallery.
    Aug 2010
    Lake Jackson, TX
    130
    Can a picture gallery be added with pictures of the common problems/finishes/equipment etc. I'm in the process of caulking my deck expansion joint and I picked up the wrong color . My lazy gene is suggesting I just use it and put some sand on top to try and blend it. A picture of what it would look like would be very helpful.
    25000 gal IG gunite plaster. Built in spa, built 1984.
    48 SF Hayward DE-4800 filter
    1 hp Hayward super pump
    3/4 hp Polaris PB-4 booster pump, Polaris 380
    Taylor K-2006 test kit
    Melt In The Sun's Avatar
    Oct 2009
    3,899
    Re: How about a picture gallery.
    We do have a photo encyclopedia of equipment in Pool School, and I tried to start one for common problems but it never took off.
    Apr 2013
    Central Massachusetts
    174
    Good idea!
    As far as the gallery goes on the front page of the website, I wish you could view it at a higher resolution! Any chance of that happening?
    26,000 gal 18x36' IG Vinyl Pool - Hayward S244T Sand filter - Hayward Tri-star 2-speed 1.5HP pump - Goldline Aqua Plus SWCG and Controller with Tcell-15 - Aquacomfort 125K BTU Heatpump - Hayward Color Comfort 4.0 LED - Zodiac MX8 suction cleaner - TF100 test kit
    My Build thread
    I was just about to post requesting a gallery when I saw this. I have several friends scouting AG pool options, Intex, to regular AG, to sunken AG. Having a gallery for ag setups, showing the pool from afar to include decks, housings for equipment, landscape around the pool, etc would be great for people wanting to see the whole gambit of options. Not necessarily the nitty gritty like plumbimg mods, but wide shots showing how it looks in a yard. Something similar in one thread would be good for IG, too. But I'd keep IG and AG separate.
    Also, might work best if people embed the pix since some past posts with picture links don't work.
    Might just start a thread in AG and hope people contribute.
    POOL: Intex ultra new in 2014 (32 x 16 x 52) (seasonal; on concrete pad covered with 1.5" extruded or whatever foam insulation sheets - ugly, but comfy); added a through-wall skimmer; I add salt for feel. EQUIPMENT: Pentair SuperFlo pump (1HP, 2SPD); Pentair cartridge filter (200 sq. ft); Pentair MasterTemp natural gas heater (400,000 btu) Climate/Location: Eastern Nebraska
    There is a large gallery of pools on the home page, the slide show. However, it does not distinguish between in-ground and above ground.
