Thread: Question about sand filter?
    cubbybeave08's Avatar
    Feb 2008
    Northwest Indiana
    902
    My buddy has an 18 foot pool with a sand filter. He has filled with water and has pump running. His problem is that he very little suction on the skimmer side. Water is flowing through, but he feels no draw of water down the skimmer. When he tries to vacuume the vacuume hose cover does not draw down and stay attached to skimmer.
    My problem is thst I dont know anything about sand filters...and their mechanics or operation. He says the pressur gage keeps edging upward, but there is no suction. I know this usually m...eans there is a bad connection or hose somewhere...but where. Or is this an issue i side the filter or with the multi valve? Any thoughts
    Beave
    Aqua Leader 24ft Round AG Wil-Bar Influence w/54 inch walls 13,500 gallons
    Swimline J-Blue Opal Liner, 1 4X20 Fafco Solar Bear Solar Heater
    Hayward 2 HP Swim Pro Voyager Pump Micro 150 with 4 way timer
    Swim Pro Voyager Filtration System with Hayward ABS Pearl wide mouth skimmer
    Mod Squad woodyp's Avatar
    Apr 2010
    East Texas
    9,659
    Re: Question about sand filter?
    Is the filter in need of a good backwashing or opening the top and inserting a hose on gentle flow to break up clumps? Blocked line? Air in the pump strainer basket?
    Oct 2012
    Central Ohio
    180
    Does your buddies pool have a floor drain?
    Rob
    Cozumel AGP 24' 14,700 gallons
    Pentair Dynamo 1.5 hp pump
    Sta-rite Cristol-Flo II 2.3sq.ft. sand filter
    SWCG,Uni-bead liner
    Borates
    TF-100 Testkit....$68,cheap insurance for a trouble free pool season
    Feb 2008
    Northwest Indiana
    902
    It wasa loose elbow connector on suction side, went overand checked it and found the elbow wasnt tightened down. We teflon taped it again and tightened it down good...reconnected the hose thar ran from pump to filter, and it was all good. Strong suction and 14-16 psi and steady.
    Beave
