Thread: Sharkline Matrix 54
    May 2012
    Houma, LA
    104
    Sharkline Matrix 54
    I'm getting close to install the wall. However, I keep reading the instructions and can't find what the white pieces of plastic are for. They are about 12 inches long and seem to go over the liner j-hook(the type of liner I have), between the top rails on either side of the uprights. Problem is they are not molded to fit curved areas.
    What I am wondering is, at each pole between each wall top rail, is there anything at all that goes over the wall/liner j-hook?
    Can anyone with a Matrix show me a pic of what it looks like on the inside of the pool at the posts?
    Also, with a unibead liner, do you have to use the plastic liner coping over the j-hook?
    One other thing. I have the Liner Armor fabric. Is it better to put the edges over the foam coves or under it?
    Sharkline 18'X40' Matrix 54 AGP(21k gallons), Pentair Sand Dollar Filter System with 1-1/2HP Dynamo, 125 lbs of ZeoBest., Hayward AquaRite SWCG w/T-Cell 15 TurboCell, Confer Plastics STEP-1 Easy Access Above-Ground Pool Steps, TF-100 Test Kit
    Oct 2012
    Central Ohio
    180
    Re: Sharkline Matrix 54
    Quote Originally Posted by cmiller73
    No you won't use the coping strips with a j-hook liner. Liner Armor will be cut the shape of your pool floor,you won't have extra material to go up the side of the cove,at least that was my reasoning when I installed my gorrilla pad under my foam cove.
    Rob
    Cozumel AGP 24' 14,700 gallons
    Pentair Dynamo 1.5 hp pump
    Sta-rite Cristol-Flo II 2.3sq.ft. sand filter
    SWCG,Uni-bead liner
    Borates
    TF-100 Testkit....$68,cheap insurance for a trouble free pool season
    May 2012
    Houma, LA
    104
    Thanks for the info.
    cramar's Avatar
    Nov 2010
    Sault Ontario
    1,143
    Personally, my foam cove had a notch for the bottom rail so I ended up putting the cove on the ground, then sand up to the the cove and then Gorilla Pad ontop of sand and cove.
    Not sure what's best on your set up, just saying what I did.
    May 2012
    Houma, LA
    104
    Taking into account that the cove is about 3 inches for the wall, the Liner Armor "should" be able to lay over the cove.
    I plan to level sand about 1.5" thick, then cove and lay the Liner Armor over the cove. Reason I think this is better is the padding will ride up the cove, making a better transition at the bottom of the cove.
