Thread: Well Water
    Jul 2009
    Gonzales, La
    220
    Well Water
    Getting ready to build a gunite pool. Only have well water available unless I truck water in to fill pool. I had someone test my well water and came up with the following results. Would you use this to fill or autolevel your pool?
    Conductivity 271
    PH 7.8
    Fe 0.09ppm
    Ca 30
    Hardness 50ppm
    Alk 120ppm
    Todd
    15x36 Gunite w/Diamond Brite(Bahama Breeze plaster), 3.5-6', Pentair Easytouch Automation panel, Pentair 3HP VS pump, Pentair CNC 420 filter, Pentair 5G color changing light, Polaris 360 cleaner w/booster, Pentair IC-20 SWG
    My pool build
    http://www.troublefreepool.com/threa...ales-Louisiana
    Isaac-1's Avatar
    SW Louisiana
    6,711
    Re: Well Water
    Overall I would say it looks good, there is some iron, but not enough to worry about
    Re: Well Water
    That iron level should be alright as long as you winterize. Iron will slowly build up in the pool due to evaporation. Winterizing involves enough water replacement that it should prevent the level from going too high.
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    18,995
    Re: Well Water
    Don't freak out if the pool turns green when you add chlorine. There's been a number of threads on that topic. It usually goes away in a day or two. If not, you can use metal sequestrant to deal with the iron.
    Jul 2009
    Gonzales, La
    220
    Re: Well Water
    Thanks for the replys guys. I was most worried about the iron in the well water more than anything. Initial fill will most probably be with tank truck from hydrant down the street. After that I will be on well water until they run the water line down our street years from now. Would a water softner or something help remove this?
    Jason we don't have much of winters around here. Probably can swim into December some years. Three months of colder weather but not like where you are.
    Todd
    My pool build
