Thread: Air in Pump Basket
    Air in Pump Basket
    Have a Pentair Variable Speed Pump. At High Speeds I do not see any air in the basket.
    If I run at 1100-1500 RPM, I do see that there is Air in the Basket?
    Is this normal at lower speeds?
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    18,988
    Re: Air in Pump Basket
    Seems like it. poll-for-users-of-variable-speed-pumps-please-read-t30272.html
    I used the search box using variable bubbles strainer and found several more.
