Results 1 to 9 of 9
Thread: Getting ready to add borates
    Tested today:
    FC 3.2
    Cc 0
    Ph 7.4
    Ta 120-125
    Cya ??
    Ch 400
    I should have cya at 50. I had zero going into the season and added solid to get me up to 50. I added last Sunday so ill check again this weekend.
    At this point am i good to go with borates, or is TA a concern?
    Jason
    30k IG plaster pool w/attached spa, Hayward Old school Jacuzzi Magnum Force 2HP single speed pump w/AO Smith motor (UST1202), Hayward 6020 DE filter, Poolskim, Polaris 380, Raypak natural gas heater, TF-100 test kit
    38,305
    Re: Getting ready to add borates
    Quote Originally Posted by jayatpitt
    Read Step 1 of the Borates Sticky.
    For what reason are you adding them?
    May 2013
    North East Ohio
    959
    Mmmm, I hope this is not a hijack to his thread, but I have been reading Pool School a bunch and I came away with these reasons why I want to add borates, once I am up and balanced, etc.
    1) more stable pH
    2) Algaestatic properties
    3) reduced chlorine usage
    4) silkier feeling water--less skin and eye irritation
    5) clearer, 'sparkling' water
    And no dogs, etc.
    So are there others reasons not to do, seems like a no brainer.
    14,750 GAL IG Fiberglass (16 x 33) NE Ohio || Jandy 1HP 2 speed Pump || Waterco MultiCyclone 16 Centrifugal pre-filter (removed due to not working with sand filter) || 30" 575 Lb. Sand Filter || AquaCal 140K BTU Heat Pump || Solar Cover || Inter-fab Adrenaline Slide || GLI Monsoon Solar Cover Reel || K-2006C Test Kit || BBB with Liquid Chlorine Stenner Injection || Rayner Mighty Mesh Winter Cover
    NoFear95's Avatar
    Mar 2013
    Phoenix, Az.
    138
    I agree with you, but I think your TA is too high to start off with.
    IG, 18K gallons, 100' Perimeter, 565 SF surface area, 980sf interior area, Max Length -36', Max Width - 16', Pentair 520 Clean and Clear Cartridge Filter, Stenner Chemical Injection System (Chlorine, Acid Coming Soon) , Pebble Tech - Blue Granite, Pentair variable speed filter pump, Zodiac MX8 Cleaner, Multi-Colored LED Lighting, Travertine coping & Decking, Boulder Water Fall....
    38,305
    1. Only really matters if you have SWG or lots of aeration
    2. Doesn't matter if you maintain adequate FC
    3. Recommended levels are unchanged ... but you might see reduced usage.
    4. anecdotal ... I don't think they affect eye irritation ... adding salt and correct pH, and no CC reduce eye irritation
    5. I guess ... how clear and sparkly do you need
    Reasons not to:
    1. extra cost
    2. struggle with pH and TA adjustments if your top-off water is high in them
    Borates are completely optional, but it seems like a lot of newer members want to jump on the bandwagon thinking they are some miracle cure or something.
    I would only worry about adding them if the pH drift was a large problem due to SWG, waterfall, etc.
    I figured...I'll get the TA down.
    I'm adding them for all the positive reasons added in the sticky...seems worth the cost.
    So on lowering TA...I understand I need to add the acid an aireate. What's the best way to get the acid into the pool? By that I mean to I just stand over the pool and slowly pour it in, get down close to the pool and pour to minimize splashing, something else? I'm a little concerned about handling that stuff...
    Jason
    May 2013
    North East Ohio
    959
    Ok, I was thinking it would benefit me as I have 6 "hot tub" style jets with air on the front half of my pool. Will be putting lots of air in the water...but I will wait and see how tough the pH is to manage, and then decide.
    Jun 2011
    Long Beach, CA
    2,790
    Jason,
    I think you are on to something here and I believe it comes from this post, so-you-want-to-add-borates-to-your-pool-why-and-how-t4921.html. How this post is written with, "a definite YES!, A RESOUNDING yes!", it seems that borates are the "miracle cure or something".
    When I first found TFP, I read a lot of threads, everything in Pool School, and it seemed that borates would be a great addition to my pool. After having borates in the water for two years, I would say that I never did notice anything different other than it took more acid to change my pH per dose, but it cut back how often I dosed by a few days. I might be benefiting from the algaestatic properties, but I can not measure it. I have to rely on the science behind it. As to the other benefits, I can say that no one in our family notices them at all.
    GreatCanadian's Avatar
    Jul 2011
    St. John's, Newfoundland
    844
    I assure you that friends coming to swim notice the effect of borates in my pool. 3 of my friends have pools and they are amazed at the quality of my water. Part of that effect is borates. They have commented on the shimmer. My pH sticks a 7.5 for the season (minor struggle before borates but not too bad). And they made a huge difference to my daughters exzema. I only started borates last year and will never go without them again. If cost is not an issue there's not much reason not to at least try it.
    GC
    13'x22'x52" 8,000 gallon ProSeries Pool with Borates
    Intex 110 pound Sand Filter with Zeobrite, 2650 gph pump, 0.95 hp
    Bestway SWG
    AquaPro ECO500 50,000 BTU heat pump
    GLI Whirlwind Solar Cover Reel, TF-100 Test Kit
