Thread: Cya, wait a week before testing
    Whatrymes's Avatar
    May 2011
    E. Bridgewater, MA
    132
    I understand it takes up to a week after cya is added before we can test reliably but how long till the product is actually working once dissolved? If I added enough product to raise my cya to 40 yesterday, do I now chlorinate as if?
    15 X 30 X 3.6 Ester williams AGP
    10,800 gallons
    Haywood EC40C90 DE filter 1 HP pump
    TF-100 Test Kit
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    18,967
    Re: Cya, wait a week before testing
    Quote Originally Posted by Whatrymes
    Sent from my SCH-I405 using Tapatalk 2
    If you hung it in a sock, giving it a squeeze should give you a hint how much has dissolved already. Once it's dissolved into solution, it's working. But some of that stuff may not really be dissolved - it could just be such fine particles that it sllipped through the weave, which is why you wait a week to retest.
    Yes, chlorinate as if the CYA is 100% dissolved. It will be a little high, but sunlight will drop it in a hurry.
    Whatrymes's Avatar
    May 2011
    E. Bridgewater, MA
    132
    Thanks Rich, always a swift and clear answer.
    10,800 gallons
    TF-100 Test Kit
