Thread: Wiring two actuators together?
    Aug 2011
    Southern California
    188
    Can anyone tell me if I wire two actuators together, to make them turn at the same time, can the Easy Touch 4P control panel handle that without tripping or going to a fault of some kind?
    I'm trying to use this panel with my existing 2 new actuators, without having to upgrade to the more expensive unit that also includes two more actuators that I won't need or use.
    I only need to move these two 180 degree actuators to switch from pool to spa.
    [attachment=0:1eav4qzt]handlecontrola.jpg[/attachment:1eav4qzt]
    22,551
    Re: Wiring two actuators together?
    The output of the EasyTouch should handle two actuators in parallel just fine.
    Jul 2014
    california
    1
    Hi Bama
    thanks for your input. I am having the same issue connecting two actuators together in parallel on an easytouch 8. Will find out how it holds up...
