Thread: Low Voltage Lighting Questions
    Jan 2011
    Northern Illinois
    116
    I have started looking at installing a low voltage outdoor lighting system and after doing a day or research, have the following question:
    1. What would be a decent downlight spotlight around between $25-$40. I know that solid brass is best, but everything I've seen is over $50. The lights will be installed on the side of our raised pool deck to illuminate an area to play bags at night.
    2. Is it possible to control lights on the same transformer individually? For example, turn the downlights I mentioned above on and off without affecting deck lights attached to the same transformer?
    3. What is the difference between an electic transformer and a magnetic transformer? For example, I actually found some Volt downlights that looked good for $50 but they require a magnetic transformer which seems to be more expensive.
    Thanks in advance for the help!
    Wil-Bar 27'x54" Quest AGP
    Hayward 1HP Powerflo Pump
    Hayward 256 T Swimpro Sand Filter
    Jul 2011
    NY
    51
    Re: Low Voltage Lighting Questions
    Volt Lighting is excellent and there customer service is very good as well. I can highly recommend them. You can pick up a compatible transformer from one of the big box stores for $50 for a 120watts. Assuming you go with LED bulbs @ 2-3watts a piece you shouldn't have any trouble providing adequate lighting with one transformer. I have 3 120watt transformers for zoning purposes. One for the pool area, one for the backyard and one for the front yard.
    In terms of field wiring I would recommend running from the transformer to a hub location and then from there to each of your individual lights with each hub could serve a 50' area. In this way voltage would be similar for each lamp connected to a given hub, insuring similar brightness for the area served by that hub. You could then order your fixtures with a 25' attached direct burial cable and you;d be good to go.
    No affiliation with VOLT - just a happy customer.
    Dave
    29,700 Gallon Vinyl Roman End, Sta-Rite Max-Therm-400HD gas heater, Sta-Rite S7M120 cartridge filter, Pool Pilot DIG-220 SWG
    Same here. Entire backyard done with volt equipment. Larger transformers have multiple circuits with would allow for 2 or 3 individual switches, each capable of controlling multiple zones. I used their transformer/cable/hubs/lights (led) and everything is of excellent quality (I'm not expert though). Did all the work myself as their website is extremely informative. No affiliation. Beyond pleased.
    15 K gal/gunnite, 600 gal attached SPA, Hayward: ProLogic, ColorLogic LED, Super II pumps, 400k BTU heater, StarClear cartridge filter for, SwimClear cartridge filter . Pentaire: booster
    http://www.troublefreepool.com/detai...l?hilit=corpus
    Jan 2011
    Northern Illinois
    116
    Thanks both for the advice. As I've researched further a couple more questions have come up:
    1. According to the Volt website, a magnetic transformer is required with their lights...is this true? If I bought a transformer from a big box (for example, Intermatic) would it be magnetic or electric?
    2. Does anyone have any experience with Paradise lighting? They are sold by Amazon and get excellent reviews. I've also read a couple of reviews other places that are very complimentary. Plus they are a lot cheaper than Volt.
    3. Does anyone have any advice on how to light our pool deck below? We're not looking for bright lights necessarily....more "mood" lighting.
    I've read that all lights must be at least 10' away from the pool so this makes lighting even more difficult.
    Thanks again!
    Lighting under the top railing would be nice. Can use LED rope lights. For simple mood lighting, use these at the top of every other panel.
    Ksnewman's Avatar
    May 2012
    Middle Tennessee
    173
    Quote Originally Posted by pmsmith2032
    I contacted Volt about use of their transformer and they are not required. I purchased 100 watt pool rated magnetic transformers from local electric supply for about $50.
    Thanks again!
    18x36 kidney 20,000 gallons IG vinyl. Pentair Easy Touch 8 w/IntelliChlor IC40. Triton II TR100. Pentair Intellifllo Variable Speed. Waterfall/Jump Rock. 2 Pentair Intellibrite lights. TF-100 Test Kit. And a very happy husband who gets to play in the pool without having to take care of it.
