Results 1 to 7 of 7
Thread: Pump run time, daytime vs nighttime
    redhdgirl417's Avatar
    Sep 2012
    Mid-Michigan
    127
    Just picked up a dusk to dawn timer for my AGP for when I'm on vacation (normally control power via breaker box in garage). Just occured to me that it will be running for 8hrs during the NIGHT, not the day, while I'm gone...is this a significant issue?
    13,900gal 24'x52" Backyard Leisure Heritage AGP
    20ml All Swirl Flat Liner
    Pentair 1.5hp Pump and 150# Sand Filter System
    Smart Step Ladder w/Smart Light
    TF100 test kit, BBB Baby!
    BoDarville's Avatar
    Jun 2012
    DFW, Texas
    3,841
    Re: Pump run time, daytime vs nighttime
    From a filtering standpoint, it makes no difference. Some electric utilities offer lower rates at off-peak times. If yours does, then you may save some electricity $ by running it during those times.
    BTW, you very likely do not need to run the filter that long (8 hours). Most people, including myself before I found TFP, run the filter much longer than needed. The Determine Pump Run Time article was recently revised. It's worth taking another look at. I have cut way back on my filter run time and the water is still crystal clear. Proper chlorination and balancing play a leading role in water clarity.
    Sep 2012
    Mid-Michigan
    127
    Quote Originally Posted by BoDarville
    Bo, thanks for the quick response! Pretty sure our utilities up here in mid-Michigan do have on and off peak pricing, so that would make hubby happy if the electric bill lower. And I will definitely check out that article...I know I'm overdoing it with my pump run time, obsession with keeping that pool sparkly clean I guess.
    frustratedpoolmom's Avatar
    SWSuburban Chicago, IL
    11,969
    Personally I like to recommend some run time during the heat of the day, at least a couple hours. I also think it helps to run the pump when swimmers are in so that the filter catches any gook that gets stirred up by swimmers....
    Sep 2012
    Mid-Michigan
    127
    I will definitely run the pump while swimmers in and when I'm home...this is for vacation purposes, where I will be gone for about a week and the solar cover will be on the pool with chlorine up to shock level.
    11,969
    Well kool then you are good to go!
    Sep 2012
    Mid-Michigan
    127
    Quote Originally Posted by frustratedpoolmom
    I first bought a really nice Brinks digital timer...that was too big for our enclosed outlet box AND didn't have a 3-prong outlet. Loved it because I could have set it for specific times. Told hubs he needs to get on hard-wiring a timer box to the breaker for me.
