Thread: Lime remover?
    Lime remover?
    The Hard water in AZ is killing me! I have a lime line on the pool tile and on the stone under the water fall. Any advice on a product to use on it? For the tile I can get it off but the stone is another story. Thanks guys.
    Mod Squad JohnT's Avatar
    SW Indiana
    9,199
    Re: Lime remover?
    Muriatic acid is the normal first choice for tile.
    Aug 2011
    Southern California
    188
    Re: Lime remover?
    Quote Originally Posted by JohnT
    What would be the procedure and would it be at full strength?
    I'm having this issue as well.
    Re: Lime remover?
    For my tile...it's had SOS pads on it before so no clear is on it. Don't judge me but I use a grill scraper! The sharp edge of it. Only works on thick lime.
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,056
    Re: Lime remover?
    Quote Originally Posted by Hawk
    1:4 diluted acid and a pumice stone.
    It'll make fingernails on a chalkboard sound, don't be alarmed.
    You can also use the search box up top.
