- May 17, 2013
- 6
I have a two speed 1.5HP Jandy FloPro Model FHPM. I’m a new pool owners so this may be very easy questions, but here goes:
1) When the pump is turned off should the basket of the pump drain 100% and have to refill each time the pump timer cycles on?
2) Should the pump be on a single or double timer? Single giving High or Low options or should you be able to timer both High and Low?
14000 gallons, IG (in ground), gunite/sunstone, cartridge, 1.5HP two speed pump, pool built 7/2012, waterfall, two spa jets
