Thread: Sidewall blowout
    Feb 2009
    Hampstead, NC, transitioning to Perfection, NC
    353
    Sidewall blowout
    The sidewall (right at the skimmer, naturally) blew out of my 16'X32' oval agp. It is completely inside a deck so changing the size is not an economical option. The only two manufacturers of this size I have found so far is Cornelius and the Pool Factory. Any input about either of these? Or any suggestions of repair? The pool is old, I live at the beach and the steel is rusting out in many places. Cost is a major concern. I've checked Craigslist, and found one 200 miles away, understand the used liner issue, so that is a factor as well.
    Thanks
    16X32 AB, Pentair SD filter, 3/4hp Pentair Optiflo, CircuPool RJ30+ swg, TF 100, 19 X 37 igv, Pentair filter, 1hp Pentair Superflo pump.
    Mod Squad woodyp's Avatar
    Apr 2010
    East Texas
    9,602
    Re: Sidewall blowout
    Dang I'm sorry to hear that. I have a Cornelius 16x32 steel wall that is ...NOT.........warrantied for a SWG. Top rails are resin. Living where you do you might want to look into a resin wall pool. I didin't even know they existed when I put mine up!
    Casey's Avatar
    SW PA
    10,444
    Just wanted to tell you how sorry I am that your pool blew out! Good luck in your search!
    Feb 2009
    353
    Thanks to both....And I am looking at resin, though the newer steel walls with hot dip galvanized/Kleer Koat should be fine with a salt pool.
