Results 1 to 7 of 7
Thread: Motor oil in pool
    Motor oil in pool
    Today I went to add liquid chlorine to start the shock process and as soon as it started coming out I noticed it was black. Used motor oil. Probably only 8 ounces or so.
    The pump is not running and the water level is not above the skimmer yet, I stopped filling it up.
    I can skim some off and have been, I ordered Pool First aid and am waiting for it to arrive.
    Any suggestion on how to proceed?
    Thank you for your help
    Mod Squad JohnT's Avatar
    SW Indiana
    9,198
    Re: Motor oil in pool
    Rags or old towels. Anything to soak it up.
    Feb 2008
    Denton, TX
    5,061
    Welcome to TFP!
    Pool First Aid is what you need and you have already ordered it. Just keep skimming what you can manually. Don't worry. This has happened before and it always ends up ok.
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    18,966
    Quote Originally Posted by nashman1966
    Welcome!
    Great first post!
    I want to see the rainbow sheen!
    John T, for the rags do you just lay them on top and pull them before they sink? I used a just one towel and was not sure if it was doing anything is why I ask.
    257- The pool first aid-does it work without the pump running? Hate to get oil in the sand filter. Pool is in ground 16x32 Hayward sand filter.
    Thanks for the responses, sounds like it will work out.
    22,537
    It might be too late but auto part stores have oil pigs and pads that will absorb the oil and not water. That's what you need to absorb the oil. Once you have as much of it absorbed as you can then use the pool first aid.
    Definitely oil pigs. http://www.newpig.com/pig/US/
    16x32 Oval In-ground Vinyl, ~17,000 gallons, Hayward 1hp Superpump, Hayward S245T Sand Filter
    Worn out sand? sand-filter-expert-help-t30049.html
    Drain the easy way: cyanuric-acid-blues-draining-pool-t43843.html
    http://tftestkits.net/splash-page.html , pool-school/chlorine_cya_chart_shock , pool-school/shocking_your_pool
