Results 1 to 19 of 19
Thread: Shock process for people with day jobs?
    Jul 2012
    California Central Coast
    74
    I was just wondering:
    I have been shocking my pool because I am not passing the OFC loss test (losing 2 ppm overnight). But I have to go to work! So I bump it up very high in the morning before I leave, but when I return home, the FC is always below shock level. It seems the higher I raise the FC, the more drastically it drops during the day. I've been going at this for two weeks now and I have run out of testing agents and re-ordered, got those and re-started, and poured through about 20 gallons of bleach. On weekends I can keep it above shock, but when Monday rolls around I have to go to work, and it falls back down again.
    So my question is: Is it impossible to do this unless you are sitting around monitoring it all day for several days? And, am I wasting my time and money because I can't be here all day and I am just spinning my wheels? My water is crystal clear, and as mentioned my OFC loss is 2 ppm. It was much higher, around 6 ppm loss until last night when I only got 2 ppm loss.
    CYA 40
    FC normally 6, shocking between 16-20
    CC 0
    PH normally 7.6
    TA 90
    CH 300
    Test Kit: Taylor K-2006
    Pool:In ground/Pebble/16,000 gal/Cartridge Filter/Pool Built appr. 1995-2000
    38,299
    Re: Shock process for people with day jobs?
    You will still make progress, just a little slower. Generally, you lose a certain % of FC to the sun that depends on your CYA level ... so the higher you raise the FC, the more you will lose to the sun.
    Sounds like you are getting closer to eliminating whatever is consuming your FC at night. I agree it can be frustrating, I pass the OCLT, but the FC loss during the day seems to be more than it should be ... but I have a LOT of AZ sun, so likely just need to raise the CYA a bit more.
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,009
    Burn up some vacation time.
    It does sound like you're getting closer. Got a nearby retired neighbor who could come over at noon and pour in a jug? Or a stay-at-home mom? I hesitate to suggest that, though, because then you'd feel obligated to invite her and her kids over to go swimming...
    Jul 2012
    74
    Richard: I could pay them to haul away the all the bleach jugs too!
    38,299
    Quote Originally Posted by ecowolf
    LOL. My wife literally just sent me a IM complaining about all the bleach bottles filling up the recycling bin and asking how the forum suggests dealing with that .... I said "Get a SWG"
    Richard320's Avatar
    Jan 2010
    19,009
    I'd ask the grade schools and preschools in the area if they have a use for the empty jugs. Some kind of arts and crafts project, perhaps? Or slice off the tops and use them as planters, or to hold the rinse water while watercolor painting, mixing papermache or fingerpaint in a disposable bucket...
    Jul 2012
    74
    Funny you should mention that Richard. I am a teacher at an art school! Why didn't I think of that?
    Seriously though: So am I correct in understanding that shocking like this still gradually chips away at the problem even if it dips below shock level for a couple of hours?
    Isaac-1's Avatar
    SW Louisiana
    6,711
    Chipper Shredder?
    Jul 2011
    Perrysburg, OH
    88
    I'm in the same boat! Opened the pool a couple weeks ago and hit it hard on the weekends. I add some bleach in the morning and again after work during the week. Still a bit cold to swim anyway and I'm real close on clarity and OCLT. Should be perfect by memorial day!
    16 x 32 inground vinyl pool (21000 gallons) (new liner installed 2014)
    Hayward max flo pump w/ 1 HP AO Smith motor (new motor 2014)
    Hayward C1200 cartridge filter (new 2014)
    Hayward H150 heater
    Went thru gallons of chlorine last year. This year I tried the "close late,,open early" way. Based more on water temp than the month or day. Opened at 58 degrees and had just a little algae started. I was easy to clear and took lots less chlorine than waiting too late like I did last year........ Guess it's the way to go..... I know it's too late this year but give it a try starting with this years closing....... You're getting there just keep at it.
    21000 Gallons I/G,,Vinyl,, 1.5 H.P. Hayward Pump,, Hayward Sand Filter S244T.. Liquidator.
    Jun 2012
    Butler, PA
    336
    Same boat here. I work M-F, we're emergency response so if emergency projects starts I go until the project finishes. I test in the morning, top it off as I should ~ add extra for the day & then test when I come home, add more and test at bedtime., adding more if necessary. I go by the afternoon's prior burn off and the weather to determine how much extra to give it at the next dose for while I am gone.
    Only been since Saturday that I got my CYA in ~ kids feel like it is taking forever & are discourage we are still seeing so much murkiness. I just told them they had to have patience & that it will eventually clear. When the cover is off though, they don't care what the water temp is or what chemicals are in it ~ they want to swim.
    Really though I don't want anyone dumping anything in or testing besides myself~ opens too many doors for a setback. So with that I just do the best I can and it seems I find a bit of religion ~ as I start "praying" it will clear & quickly. I am anticipating a couple nice mixed drinks and some good tunes in sparkling water~ it really can't clear fast enough for me either
    AGP: 27' x 52" : 17,500 gallon
    300 lb. Sand Filter (75 gpm) / 1.5 hp pump
    Full Sun ~ All Day
    BoDarville's Avatar
    Jun 2012
    DFW, Texas
    3,841
    As someone who also works in an office, I understand this dilemma. I'll throw some ideas on the table and perhaps one or more will work for you. Disclaimer: Some of these ideas will not necessarily be convenient, but just think...it's only temporary
    Work From Home (WFH) for a few days
    Come home for lunch, assuming you don't have a killer commute.
    Wake up two hours before you leave for the day. This will allow you to get two tests/dosages in before you leave.
    Burn a few vacation days as Richard320 suggested.
    Work half days. Several companies allow their employees to use PTO on a half-day basis
    Work the morning in the office and the afternoon from home
    Is there a trusted teen / friend nearby that can test/dose during the day? You could compensate them by $ and/or throwing a pool party when the pool is ready.
    frustratedpoolmom's Avatar
    SWSuburban Chicago, IL
    11,969
    Silly question but are you shocking in the evening? If you hit it hard in the evening and take the sunlight out of the equation?
    Jul 2012
    74
    Poolmom: Yes, I am shocking in the evening, but at "normal schock levels" does bumping it higher do any good? I assumed shock level was shock level and that was it. Bad assumption?
    11,969
    Are you shocking once or are you testing hourly in the evening until bed? No normal levels suffice.
    Jul 2012
    74
    A little of both. At first I was just testing after the sun went down, figuring that was a good base-line, then I noticed how much I was losing even after sundown and I started feeding it bleach even after sundown and then testing before bed time. I'm getting the sinking feeling I've been doing something wrong....
    11,969
    K lets review your CYA level - how confident are you in the result? How did you test it?
    Jul 2012
    74
    It has been a bit strange. Last year after several partial drains and refills I got it down to 45 and it stayed there consistently. This year at opening it was at 40, which seemed a bit odd, but I figured maybe I had more splash-out than I realized or something. I tested it a few days ago and it filled the whole tube and the dot never dissappeared. I then found a small leak in the heater connection and figured the water loss there was causing me to add more water than normal and drop the CYA. I chlorinated once with dicholor to bump it back up, and the next time I tested it was somewhere between 30 and 40, so I rounded up to 40. Tested again recently and got the same result. Maybe that one weird reading I made a mistake, I don't know. But the whole time I have been shocking based on 40, to be on the aggressive side.
    I am testing with a Taylor test kit, and have read all instructions, watched all the videos, and read all the posts on here I could find about testing CYA; waist level, north light, etc.
    Apr 2010
    Buckeye, AZ 85326
    619
    Two weeks seems like a long time to be in the shock process. Your pool seems like a good candidate for a night time nuking. If all your tests are correct and your equipment is solid I would just blast the heck out if at night. Or even a weekend of nuking if you've got something really nasty in there. It seems like you are just spinning your wheels at this point or something is fouled with your testing. Hoefully you get it knocked out soon.
    11,872 Gallon IG Shotcrete play pool
    Blue Granite Pebble Sheen finish
    Hayward SwimClear c4025, Navigator & Tristar 1.75hp pump
    2' Powerfall
