Thread: Intex 2650 sand filter ?
    Jul 2011
    Kenilworth, NJ
    12
    hello all, i just bought the intex sand filter, on the plug, it has a test and reset button. can the plug be cut off and a new plug without the test/reset button be installed?
    thanks
    danny
    Intex 16' x 48" Ultra Frame
    Intex 2650 GPH Sand Filter
    Intex Krystal Clear Saltwater System CS8110
    38,428
    Re: Intex 2650 sand filter ?
    Why?
    That is the GFCI protection. If your outlet is also GFCI protected, then it should be OK to put a plain plug on it (not sure about code though). Or it could be hardwired into a timer that is on a GFCI circuit.
    Jul 2011
    Kenilworth, NJ
    12
    the outlet is GFCI protected, the main reason for wanting to cut it off, is, everytime i go to vacumm the pool, the pump is not running, and if i kick on the pump manually, it screws with the timer setup for the pump and my seperate intex salt water system. i put it on a outside timer, and when the timer kicks the pump off, and then when the timer goes to turn on, the pump wont go on because it trips the plug reset.
    danny
