Thread: Pressure Gauge Replacement
    May 2013
    Erie, PA
    53
    Hi Everyone,
    When my filter is off, the pressure gauge only goes back down to around 2, not 0. When the filter is on, the gauge seems to be working fine and reads 15-16 (Just opened the pool and its gotten to 18 but bumping brings it right back down to 15).
    Should I replace it? Wasn't sure if the fact that it stays at 2 when the pump is off is giving me inaccurate readings.
    Thanks!
    22,700 gallon, 18x36 Vinyl IG - Hayward EC65 Perflex DE Filter
    38,271
    Re: Pressure Gauge Replacement
    Welcome to TFP!!!
    I think it would be best to replace it. No telling if is still showing the correct pressure relative to 2psi instead of 0. A liquid filled gauge is better, but costs a little more. You can find the non-liquid ones for under $10.
    May 2013
    Erie, PA
    53
    Great, thanks for the reply! Will go ahead and just buy a new one.
    This is my first post but TFP has helped me out countless times! Thanks!
