Thread: Question for variable speed pump owners
    Where do we take the initial readings from as far as a "clean" reading goes? cause on high the pressure is at 11... on low... it's 0... <--- not sure if that really is a good thing or not. LOL
    27' Round Sharkline Venture 17K Gallon AGP
    Pentair SD80 26" Sand Filter
    Pentair Dynamo 1.5HP Dual Speed Pump
    45MPHP10 Stenner Pump
    Aquabot Pool Rover Jr.
    38,251
    Re: Question for variable speed pump owners
    For a 2-speed you want to use high speed. For a VS you want to use a "high" RPM ... likely 2000+ rpm.
    Then you just have to check that speed to know when the pressure has risen 25%.
    Also, you want to be sure that you always use the same valve positions when checking the pressure as they can have a large effect on the pressure.
    ok... i have the 2 spd in my sig, so i'll go with the high setting pressure then... i guess every now and then, i'm going to have to switch it over from low (as that's where it's gonna be set to 99% of the time).
