Results 1 to 8 of 8
Thread: Am I headed in the right direction?
    Jun 2010
    Dayton, Ohio
    241
    This is how my pool looks on day three of shock process. I will say I do not have a good test kit yet but I have ordered it. When I opened my pool it was green and cya was 0. I have put in 4 pounds of stabilizer and 16 bottles of 121 oz. bleach from Wal Mart. My pH is a little high but it has been raining like crazy here. Soooo I guess my question is do I maintain shock level and be patient or am I missing something....
    The pool is actually more blue than this picture shows. Just very milky. I tried to post picture it's just not happening! I feel stupid!
    You almost had it! I just adding the Img code around your link for you Butterfly
    AGP: 24' x 52" cartridge filter: 13,500 gallons. Taylor K-2006 test kit.
    Mod Squad JohnT's Avatar
    SW Indiana
    9,199
    Re: Am I headed in the right direction?
    Looks like you are on the way. Ignore your pH while shocking. The chlorine can interfere with the pH test.
    Brush or vacuum daily and scoop out any debris on the bottom to speed things along.
    Jun 2010
    Dayton, Ohio
    241
    I have been brushing walls and floor a few times a day. There is actually no debris on bottom so that is good. It was just green when I opened it. I could see the bottom when I took off cover. so the water was green but clear and the bottom was gross. I just keep pouring in bleach. I feel like there is more bleach than water in my pool!
    Mod Squad woodyp's Avatar
    Apr 2010
    East Texas
    9,581
    .............and keep your filter clean to help speed it along.
    Jun 2010
    Dayton, Ohio
    241
    just wanted to make sure I was headed in right direction. I just need to be patient! oh. and clean my filter.
    Butterfly's Avatar
    South Carolina
    10,045
    Yep, stay the course and be patient. Have some popcorn , a can of POP, and your fav libation
    You're done SLAMing when:
    Jun 2010
    Dayton, Ohio
    241
    Thank you so much for fixing my picture! and I sit and stare at my milky pool and have a few adult beverages!
    Butterfly's Avatar
    South Carolina
    10,045
    Quote Originally Posted by passionsrlz
