IC40/Easytouch Has No Diagnostics, But Seems To Make Cl
May 23, 2012
50
I have run into an unusual problem on startup this year.
I have an easytouch 8 with an IC40 cell. I reconnected the cell, turned the power back on, and everything seemed to work without a hitch. The green lights came on, the flow indicator was good, and the salt light is green.
However, when I go to the control panel on the Easytouch and look at the diagnostics for the Chlorinator to check the salt ppm (Which did work fine last year), I get a message that there is no Chlorinator!
I rechecked the connections, and everything looks ok otherwise. Has anyone else run into this before?
