Thread: IC40/Easytouch Has No Diagnostics, But Seems To Make Cl
    I have run into an unusual problem on startup this year.
    I have an easytouch 8 with an IC40 cell. I reconnected the cell, turned the power back on, and everything seemed to work without a hitch. The green lights came on, the flow indicator was good, and the salt light is green.
    However, when I go to the control panel on the Easytouch and look at the diagnostics for the Chlorinator to check the salt ppm (Which did work fine last year), I get a message that there is no Chlorinator!
    I rechecked the connections, and everything looks ok otherwise. Has anyone else run into this before?
    _____________________
    15K IG Fiberglass
    IC40 + Easytouch + Superflow 1 HP 2 speed
    Sherlok 120, MaxETherm 200 HD Heater, Southeast Michigan
    Re: IC40/Easytouch Has No Diagnostics, But Seems To Make Cl
    There is a data cable that connects the EasyTouch panel to the IntelliChlor power supply. Make sure that cable is connected at both ends and is not cut or badly nicked.
