Hoping someone can help and save me a trip from a pool repairman.
The hose that connects the pool cleaner to the side of the pool fell out today while my daughter was swimming. I noticed it a couple hours later and popped the hose back in the side of the wall -- I don't know if it is suction or pressure, we bought the home and pool was already here. I then noticed our heater has a message reading "Err," which I take mean "error." I assume the two are related because I've never seen the heater on like this. The heater only heats the spa and the propane tank is empty. The only time I've seen it illuminated is when a pool man was here to show me how to operate the EasyTouch system.
Not sure if it is relevant, but we also installed an IntelliFlo variable speed pump a couple weeks ago and the installer told me the pump won't run if, for instance, there are holes in the pool cleaner hose that don't let it get enough suction. I imagine the hose popping off could have set something off and is the cause of this error message?
The pool cleaner is currently running fine.
Is there anything I can do to address the "Err" message?
In the photo, Power, Pressure SW and Remote have green lights illuminated. Service has a red light and Off has a yellow/orange light.
