Results 1 to 17 of 17
Thread: DIY Solar Heater from LDPE ?
    JesseWV's Avatar
    Apr 2011
    North Central WV
    526
    Has anyone had any experience making a DIY solar heater out of this type of Poly Drip Tubing ?
    It's 1/2 in. x 1,000 ft. Drip-line. It's made of low-density polyethylene and coated with a UV inhibitor. It's rated up to 80psi which is plenty for my purposes.
    16k gal, 28'x3.5', Vinyl A/G, 1hp Pentair Dynamo 2-speed Pump, Hayward S160T Sand Filter, Intermatic HB800RCL Digital Timer, Intex 8110 SWG, TF-100 Test Kit, SpeedStir Author: Jesse's Graphical Pool Testing Log
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,055
    Re: DIY Solar Heater from LDPE ?
    Here's an old thread on that topic: please-help-with-my-diy-solar-heater-t13809.html
    linen's Avatar
    Jul 2010
    Twin Cities, MN
    8,649
    Solar heating is mostly about surface area. So even if that size was perfectly efficient, it would still only be around 40 sq. ft. which is equal to about 1 2X20 panel which can be bought for ~$100. In addition, the large diameter and the long run (unless a header is fabricated to run more lines in parallel) makes the efficiency of this design even less (not even close to the 2X20 panels...and others available).
    JesseWV's Avatar
    Apr 2011
    North Central WV
    526
    The reason I want to make this heater is actually all TFP's fault. The water is for the most part perfect all the time and only requires a little acid every now and then. I guess I just wanted to make a DIY heater out of sheer boredom, thanks to TFP.
    I guess I'll check out eBay for some panels, at least I'll have a little work mounting them to the roof and plumbing them in.
    Isaac-1's Avatar
    SW Louisiana
    6,711
    The first solar heater on my pool was made from similar tubing 25+ years ago, commercial panels beat it in every respect.
    38,475
    I had 2500 feet of 1" poly on this house when we moved in. It did ok, but was always fighting leaks since it would not drain in the winter. Much happier with the panels now which more than double the square footage.
    Mar 2013
    Yucaipa CA
    87
    Here's a DIY solar pool heater site with references to several different systems.
    http://www.builditsolar.com/Projects/Po ... eating.htm
    Just throwing tubing up on the roof is asking for failure, which is why i think alot of the coil type systems don't work well. If you really want to try it, copy a system that works well.
    skeeter
    47 yr old(1977) 18,000gal Kidney shaped 38ft long plaster Pool with built-in Spa, Pentair Intelliflo VS3050 Pump, Pentair 48sf DE filter, Raypack RP2100 gas heater. HTH 5-way test kit
    JesseWV's Avatar
    Apr 2011
    North Central WV
    526
    So what manufactured systems provide the best "bang for your buck?"
    38,475
    Most panels have very similar heating performance ... there are some differences regarding efficiency when conditions are "off" ... like windy, etc
    So the most bang for the buck is in the lowest price for a reputable brand. There are a lot of panels for sale on Ebay for under $100 and you should be able to find discussions about most brands in the forums.
    JesseWV's Avatar
    Apr 2011
    North Central WV
    526
    So I'm seeing Enersol, SmartPool, Game, Horizon and Splash. Are these all "reputable?" I notice the majority on eBay are Game "dome" type. Those look almost like a DIY job with a cover.
    Administrator Leebo's Avatar
    Jul 2011
    Eastern Ohio
    7,106
    We've got 300' on the roof of the "pool house" now of the pipe. On a sunny day you can feel warmer water flowing from the returns, but not sure just how much of a gain we receive. Like you stated, we played with the idea mostly out of boredom. If true heat was wanted, I'd stay with panels.
    38,475
    Forget the domes ... stick to the panels. I don't recognize any of those names, but a lot of things are rebranded.
    I would check out solar-discounters as they seem to have reasonable prices, carry a lot of name brands and have been around for awhile. They have some stuff on ebay too.
    Isaac-1's Avatar
    SW Louisiana
    6,711
    Bang for the buck is relative when you consider life expectancy vs labor cost to replace, etc. There is also the question of header size, as there is usually a $20-$40 per panel premium if you want 2 inch headers only really needed on banks of more than about 8-10 4ft wide panels. Another thing to be ware of is the warranty on panels, many warranties only cover installations by their licensed dealers, some major panels are available to the DIY market mostly through private label programs (Auqatherm through Elm Distributing, and Techno Solis through Solar Direct), private label panels are covered through the private label company so if buying from Solar Direct you would have to deal with them on warranty issues, not Techno Solis). There are a couple of other common gotcha's on warranties in the solar panel market, first none cover freight, and some offer a prorated deal where after X years all it means is the ability to buy a replacement panel at 1/2 of suggest retail price (which is all too close to every day discount price available online)
    Regardless there is no one right solar panel, it partly depends on your climate, type of installation, etc. For example a flat rigid panel like the Techno Solis panels I have may perform better when installed at less than ideal angles and when there is wind as opposed the rippled tube style that AquaTherm made popular which may provide more area for solar absorption if mounted facing due south with little wind. By contrast the rigid Techno Solis panels may suffer more from expansion stress if partly shaded, which is not a problem in my location until late in the day when the sun is going down.\
    Ike
    p.s. I bought mine from poolheatpumps.com and was very happy with the transaction even though they did take 3 weeks to arrive, after getting them home and unloaded I found I was missing a fitting from one of the pre bagged panel kits (later I found one of the other panel kits was over one on a different fitting), I emailed my rep at poolheatpumps.com and they sent me a replacement kit, no questions asked. Price was also cheaper buying my Techno Solis panels from them with 2 inch headers than buying the rebranded 1.5 inch headers would have been from Solar Direct (big savings were on freight price)
    JesseWV's Avatar
    Apr 2011
    North Central WV
    526
    The front roof faces SSE (about 155) and has no source of shade except for the tree lines on the horizon at sunrise and sunset. There is little to no constant wind except during weather events.
    Isaac-1's Avatar
    SW Louisiana
    6,711
    Are you limited by roof space? In other words is it worth it to you to pay more for a slightly higher efficiency collector, or do you room to add an additional cheaper collector. In other words if collector A is 5% more efficient, but cost 15% more than collector B which one would you pick?
    JesseWV's Avatar
    Apr 2011
    North Central WV
    526
    Roof space is not an issue. I suppose starting with a cheaper panel that I can add on to later would be a good option.
    cramar's Avatar
    Nov 2010
    Sault Ontario
    1,143
    If your looking for a project then getting commercial panels will be plenty of project!!
    My own project turned out to be more work than originally anticipated, not hard, just more.
