Results 1 to 9 of 9
Thread: New Home owner!
    May 2013
    Tucson AZ
    5
    New Home owner!
    Greetings everyone! We are New to AZ and this forum. We've just closed on our home this past Friday which was a foreclosure. We had a home inspection done prior to purchasing the house and the pool. It was noted the pool has issues. Pump needs replacement, Quik clean Infloor actuator needs replacement, Hayward heater doesn't fire up, (This is for the spa) before any type of diagnostic can be ran it needs a circuit board and the timer needs replacement. I've got a contractor coming out to get the pool up and running but me and the wife want to do our own service / maint. I've ordered the TF-100 and think I will go with the BBB method to maintain the pool. We both are reading and rereading Pool School.
    Here is my problem, the size of the pool, I've include a picture of the of the pool, it's a different shape. 30 x 22 at the widest point and 4ft shallow and 5ft deepest. I know it's important to know how much water is in the pool... We are going to go shopping for pool supplies, can anyone provide a list so we are not wasting money.
    Also is it worth the extra $600 to go with the Intelliflo Variable Speed? The pump quoted was $900 but the upgrade Intelliflo will be $1500. I'm thinking I will make my money back in a year or so just on electric cost.. Am I wrong in thinking this??
    17k gallon, IGP Plaster with spa, Hayward Cartridge Filter, Intelliflo Variable Speed 1.5hp, Quick Clean III In-floor actuator.
    Zodiac Baracuda G3 Robot Cleaner, TF-100 Test Kit.
    Upgrades projected: 400sq ft Heliocol Solar Heating, Pool resurfacing and deck repair.
    linen's Avatar
    Jul 2010
    Twin Cities, MN
    8,649
    Re: New Home owner!
    Welcome to tfp, NiwRoC
    Quote Originally Posted by NiwRoC
    It is hard to say from the picture (it is at a very shallow angle) and the dimensions you gave. Maybe a drawing from above with more dimensions?
    Until you get your kit, it is hard to say what you will need...but for sure you will need bleach/liquid chlorine.
    A year would be real fast, unless you have astronomical rates. Is there just one pump for spa and pool?
    BoDarville's Avatar
    Jun 2012
    DFW, Texas
    3,841
    Re: New Home owner!
    NiwRoC:
    Welcome to TFP Nice looking pool.
    I agree with linen that a one year payback on the VS is very optimistic (and unlikely). Again, it is dependent on your electric rates. The general rule of thumb is unless your kWh rate is greater than $0.20, you're better off with a 2-speed from an economic standpoint.
    BTW, JasonLion recently did a thorough analysis focusing on the economic comparison of various pumps (single-speed, 2-speed and VS) here: http://www.troublefreepool.com/energ...on-t59139.html. This analysis is about halfway down the first page.
    Also, the Determine Pump Run Time article was recently revised within the past week or so. Worth another look. You may find that you do not need to run the pump as long as you might think.
    May 2013
    Tucson AZ
    5
    Re: New Home owner!
    Recieved my TF 100 and did a test on the pool today...
    Cl 1.5
    pH 7.5
    FC 2ppm
    CC 0.5
    TC 2.5
    TA 200
    CH 290
    CYA 50
    Please advise!!
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,052
    Re: New Home owner!
    Cl 1.5
    pH 7.5
    FC 2ppm
    CC 0.5
    TC 2.5
    TA 200
    CH 290
    CYA 50
    Please advise!!
    Chlorine is too low. But to figure out the dosage, you still need to calculate the volume.
    May 2013
    Tucson AZ
    5
    Re: New Home owner!
    Pool tech who came out and did the new pump install, said we have about a 11k-13k pool. So I went with 12k. Will the 1k either way make a huge difference? I used the pool app and it stated 2 gallons of chlorine.
    Vette's Avatar
    Jul 2012
    Ohio
    404
    Re: New Home owner!
    Add the chlorine and test 30 minutes after (with the pump running) to see how much the chlorine adjusted. 1k won't make a huge difference, but its always better to err on the side of safe.
    11,700 gallon 21' round 54" deep all-resin AGP - June 2012
    Waterway 1HP 2-speed pump / 100 sq ft cartridge filter
    Hayward 150,000btu Natural Gas heater
    I use and recommend the TF-100 for testing
    May 2013
    Tucson AZ
    5
    Re: New Home owner!
    I will pickup some chlorine from the store on the way home and go from there. Thanks for the advice and speeeeedy post! <3
    linen's Avatar
    Jul 2010
    Twin Cities, MN
    8,649
    Re: New Home owner!
    Assuming the pool tech was right, then no...no big difference....If as you add chemicals, you are not getting the expected change, then maybe revisit the volume then.
