Results 1 to 10 of 10
Thread: Water Level
    Modawg2k's Avatar
    May 2013
    Phoenix, AZ
    334
    Water Level
    Hey guys, should my water level be halfway up my tile? My water has been about a quarter of the way up for awhile now. I do have a leveler that I will try to figure out how to raise the level.
    ~15k gallons, 3'-5'-4' Figure 8 Shape In Ground
    Wetedge Satin Matrix Interior (Pebble)
    Paramount In-floor System
    Pentair IntelliFlo VS 3050, Pentair Triton II TR100 Sand Filter
    Pentair Intellichlor IC40 SWG
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    18,983
    Re: Water Level
    It should be about halfway up the opening for the skimmer.
    What you have is probably an autofill. Most of them have essentially a toilet float setup inside. Recently discussed in this thread. http://www.troublefreepool.com/autof...gh-t56852.html
    Modawg2k's Avatar
    May 2013
    Phoenix, AZ
    334
    Re: Water Level
    Thanks, I will check out that thread. Here's a pic of my leveler.... a Paramount Paralevel. I know I have messed around with it in the past few years and didn't seem to get any results.
    Modawg2k's Avatar
    May 2013
    Phoenix, AZ
    334
    Re: Water Level
    I don't really understand the basics of the leveler. Does the water that surrounds the leveler go into the pool? Because the water in there looks pretty nasty.
    Richard320's Avatar
    Jan 2010
    18,983
    Re: Water Level
    Quote Originally Posted by Modawg2k
    It should!
    I've never heard of this thing before, and I've read a lot of threads! But a quick google search turned up the manual. Maybe with the thing in front of you and the manual, you can figure it out.
    http://ak.poolsupplyworld.com/wpdf/p...al-startup.pdf
    Modawg2k's Avatar
    May 2013
    Phoenix, AZ
    334
    Re: Water Level
    Thanks, I can already tell from the manual that mine isn't on right. The ribs on the floater aren't straddling the ribs on the in the housing.
    Modawg2k's Avatar
    May 2013
    Phoenix, AZ
    334
    Re: Water Level
    So I toyed around w/ the leveler today and when I turned it to the left, the water started overflowing. I had to turn the water off at the source. Here are some pics of the Paramount Paralevel. Does this now look like a standard water flotation? Also, I tried screwing it back on but water still flows up out of the hole. Is there something special with screwing these things back in??
    Modawg2k's Avatar
    May 2013
    Phoenix, AZ
    334
    Re: Water Level
    Whoops!
    Jun 2012
    Louisville, KY
    266
    Re: Water Level
    LOL! Nice pic. Looks like it works like a regular ball **** from a toilet. That yellow float closes the valve on top as the water rises.
    If it's anything like a toilet, that valve and the seal can wear out over time.
    18x36 inground vinyl lined, Hayward sand filter and tablet chrolinator, approx 18k gallon
    Modawg2k's Avatar
    May 2013
    Phoenix, AZ
    334
    Re: Water Level
    Called them and apparently I am missing a tiny o ring. It's being shipped to me.
