Results 1 to 13 of 13
Thread: new SWG and sand
    new SWG and sand
    Well, this is our first year with the SWG and Sand filter. We just opened the pool. This was also our first year leaving it up all winter. It is LOADED with what looks like algae debris to me. I don't have any sort of mechanized vacuum so Questions are:
    Do I start the filter alone or start with the SWG right away?
    How do I get all that sludge out of there?
    Do I add CYA now or wait until it is clearer?
    right now it looks and smells like a pond!
    16ft X 52in Intex Ultra Frame
    Intex Krystal Clear Sand Filter 16in and Saltwater System
    (the filter is new this year)
    Re: new SWG and sand
    Get the filter running. You can turn on the SWG, or not, but you are going to need to shock the pool. Before you start in on shocking, you should get as much of the debris out of the pool as you possibly can. A (pool style) leaf rake is a good tool to use. You can also use a pool vacuum, though that often doesn't work so well when the visibility is bad.
    You want CYA around 30 (if practical) when shocking. Raise CYA up to normal SWG levels only after the water is all cleared up.
    Jun 2012
    Howell, NJ
    977
    First you need a good test kit. See the link in my signature. While you are at it, get a salt test since you have a SWG. I don't have a SWG, so I am not sure whether to recommend the strips or drop kit. Then you will need to post up a full set of test results. Scoop out all of the solid debris you can while waiting for the test kit. You can use a leaf rake or skimmer. After you get the kit, you will need to follow the shock process, which is in my signature. No sense using the SWG since it won't be able to keep up, and will just use up the cell life.
    John
    7 year old ~13,500 gal 24' AGP with 1.5 hp Proline pump, 150 sqft Pleatco cartridge, filled with well water with pH of about 4.5.
    Wanda the Whale pool vacuum, home made heater, Taylor K-2006
    Cloudy Pool? 1) Order test kit. 2) Follow SLAM
    New to TFPC? Read Pool School a few times, then post questions. PoolMath will help with chemical additions.
    So, which method of shocking the pool do you reccomend? Chemical or the boost on the SWG?
    I don't have any large 'chunks' of debris anymore but when I tried vaccuming with the one included - the one you put on the hose - all it does is stir up all the water and make it dirtier. I have the filter running and when I back wash it is really gross color and then clears quick. I hope this means that the filter is working!
    I don't understand the copper level testing? If it is low, you boost it more, but this raises the chlorine as well. I do think it is better than yesterday since I started the SWG. Does that mean there is dead algae as well as live? Need to order my test kit yet just wan't sure if the chemical issues were improtant before I cleaned the water...
    Jun 2012
    Howell, NJ
    977
    Complete the Shock Process (link in my signature) using liquid bleach. You really should disconnect the copper bars, because at levels needed to keep algae away, it also may/will cause staining.
    John
    John, I don't understnad about the copper bars? So do i just run the filter and use the bleach to shock?
    Jun 2012
    Howell, NJ
    977
    I'm not familiar with Intex SWG's but I know they have copper bars in them. I now there is a way to unplug them, but I will let someone with experience help you with that. As for the shocking process, yes run the filter and use bleach for now.
    Here is a link about the copper bars. Hopefully this will help you with disconnecting the copper. intex-swg-with-copper-t59740.html?hilit=intex%20swg%20copper
    John
    John, yes I see the bars and and I see how to remove them and not use them. SO - get the bleach in, and run the sand filter. Right? How often to back wash?
    I did check a quick FC and it was 2. So I can use the calculator to figure out the bleach amount right? Also what happens if I run the copper now?
    38,271
    Backwash when the pressure goes up 20-25% of the clean pressure.
    Yes, use the poolcalculator.com to determine how much bleach you should add. Have you added CYA yet to know what your shock FC target level is?
    Jason, I have not added CYA.
    Is the only way to get the fine particulate matter out by filtering, filtering, filtering?
    38,271
    Basically, yes. You can try this if you are not seeing improvement:
    pool-school/add_de_to_a_sand_filter
    Jun 2012
    Howell, NJ
    977
    If you run the copper, you run the risk of it getting too high and causing staining of the pool. It can also cause blonde hair to turn green.
    John
    Well the water is clearing nicely. still a little green, but clear/see through. However, all the **** is on the bottom again. Less aqlgae floating on the top, and the pond smell is gone. So, if I were to invest in a vacuum, any advice? I really cant invest too much more this year, given the new pump/filter/SWG.
