Thread: Poll for Borate users
    maxepr1's Avatar
    Mar 2011
    DFW
    716
    I'm going on year 3 of BBB, I have not added ANY additional Borates since I started the method! Can this be right? No real measurable water loss other than backwashing and evap. I measured the other day, still 50, same as last year! I guess I want to know what are you guys seeing and doing each year?
    40'x19' IG Diamond Brite 29K 4' Waterfall/Dive Rock FNS60 DE Inteliflo VS 2hp Whisperflo pumps Aqualogic(P4) SWG TF100 Tester
    Pool School, Pool Calculator,TFTestKits,
    mariane's Avatar
    May 2012
    Southeast Michigan
    305
    Re: Poll for Borate users
    I have to reduce water level for the winter freeze and add new in the spring, so I have to replace borates every year. I use the Borax and Muriatic Acid method to add borates. I'm not sure it makes a lot of difference in my pool but I like to do it anyway.
    There is a very long thread talking about this topic. so-you-want-to-add-borates-to-your-pool-why-and-how-t4921.html
    Not sure if that helps but hope it does a little.
    16 x 28 Doughboy Mystic Garden AGP with 7' deep end (used expandable vinyl liner) ~11,800 gals. Deep end main drain. Thru-the-wall skimmer, one return at deep end. Media Master 150# sand filter. Doughboy PowerPak II pump, 1 hp. Pentair MinimaxCH 150m natural gas heater. Polaris 65 when it feels like working . TF-100 test kit. No longer 'pool stored' 6 years and counting. In sunny but fickle metro-Detroit.
    Swampwoman's Avatar
    Apr 2012
    Grand Rapids, MI
    3,777
    I used boric acid last year and my reading on opening looked to be about 45.
    I'd started from 50, but had topped up a little midsummer ( lots of splash out and evaporation.)
    So lie you, I didn't lose much over winter anyway.
    In ground vinyl Grecian, 24k gal, Hayward 220t sand filter, VGreen VSP 165, Hayward SWG, Raypak NG 265k heater, dolphin m4.
    Helpful Links:
    GET A TEST KIT Chlorine/CYA Chart How to SLAM About Metals & Stains
    thehowheels's Avatar
    Apr 2013
    SoCal
    120
    How are you testing for Borates? The LaMotte test strips don't have a very fine range on results, 0-15-30-50-80. My understanding is that borates, like CYA, doesn't evaporate. So you'll only see a loss through backwashing, draining, and splash-out.
    Matt
    9k gallon, plaster, IG. Raised spa w/ spillover into pool. AO Smith Century Centurion / Purex Triton WisperFlo 0.5 HP, Hayward 1.5 HP (spa), Polaris 1-516-01 1.5 HP (blower). Hayward DE3620 36 ft2 72 GPM DE Filter, Polaris 145 cleaner. Pool built ~1980.
    Trouble-free, BBB since: April 25, 2013
