safe to run the pool filter with filter set on closed? and have the water running thru the deck jets?
Was thinking that it would still be too restrictive?
PH 6.7 with water heater, so wanted to use the deck jets to raise the PH. but would have to set the filter to closed so the water doesn't go thru the filter/heater.
I have a deck jet valve before the pull filter/heater. So could direct the water from pump to deck jets, but was thinking that it would still be to restricted for water pump. 220v pump.
thanks, hope someone understands this post? lol
