Thread: confused about test strips
    May 2008
    Massachusetts
    2
    This is my first pool and I went with the Intex SWG right away. I'm confused about the 3-way test strips that came with the SWG. I tested the water yesterday and the "free chlorine" was the only thing in the OK range. As instructed in the SWG guide I had added the correct amount of salt and waited 24 hours with just the filter running to make sure it had dissolved before switching on the SWG. When I set the SWG yesterday to run for 3 hours it did so, and when I checked it in the evening the last code to be displayed had been 93, so all is well.
    What I don't get is if the SWG is not telling me the salt is too high or too low, then why are the 3-way test strips not accurate? I'm airing on the side of caution and won't use the pool until I'm sure it's safe. Can someone tell me if I need to have all 3 things on the test strip be in the OK range, or do I just care about the free chlorine levels with the SWG system?
    26,000 gallon inground pool & separate spa
    DE filter
    solar heater
    Welcome to TFP!
    There are a number of different levels that need to be balanced. The SWG only helps you with the free chlorine level. You still need to adjust PH, TA, CYA, and salt manually.
    You might want to try reading some of the Stickies. See the link in my signature or the sub-heading of every page. There is lots of good background material there. A good place to start is the BBB for Beginners article in the May 2008 newsletter, just below the Meet the Members introduction.
    ivyleager's Avatar
    Sep 2007
    Raleigh-Durham,NC
    489
    Re: confused about test strips
    Quote Originally Posted by completenovice
    Pssst....test strips are horrible! Fairly inaccurate. A good test kit is the way to go.
    CaryB
    36 x 18 IG vinyl, 25K, 1 HP pump, sand filter
    1 skimmer, 2 returns, no main drain
    Old school: PoolSolutions test kit
    I second that. Buy a test kit like the TF Test Kit. The link is in JasonLion signature.
    I got it and it helped/helps me a lot.
    Don
    SW Florida
    10,000 gal in ground concrete pool
    Pentair Cartridge filter
    Pentair Intelliflow pump
    Pentair SWG
    using BBB for pool chemistry/Lamotte ColorQ tester for daily testing
