Thread: New to the forum - Starting up - Lots of silt
    May 2013
    Houston, TX
    12
    I read the very helpful sticky about starting up, but I'm afraid my pool may not quite be ready to proceed. Especially since it says to keep the pump running. Couple of issues:
    1) It's got lots (LOTS) of silty material - must this all be removed before running the pump?
    2) When the pool was almost started up about a year ago, the pump would run for a while and then lose pressure. Is that reason to just replace it?
    3) I would like to have new water, but I'm told that if I drain the pool, it can pop out of the ground. Is that true?
    The pool is completely green and I think frogs have been breeding in it and it's occurred to me that they have no way of hopping out after, so imagine the worst possible situation. It was never covered and shut down.
    Marie
    30-33 K gal (I think) plaster, Hayward DE Filter 60 sq ft, Main pump 2 HP Magnatek, Spa pump 1 HP Hayward (jets installed backwards), Waterfall pump .75 HP, phantom cleaner (broken)
    linen's Avatar
    Jul 2010
    Twin Cities, MN
    8,649
    Re: New to the forum - Starting up - Lots of silt
    Welcome to tfp, cheekynewb
    Quote Originally Posted by cheekynewb
    Remove what you can, the rest will can be filtered out, or in extreme cases vacuumed to waste.
    This could be do to a suction side leak, a vortex sucking air in at the skimmer, or a stuck weir. It probably would not be rectified by replacing the pump. The number 1 place for a suction side leak is the pump basket o-ring leaking.
    What kind of pool do you have? In ground or above ground? Vinyl, plaster, fiberglass?
    Start by looking at this post: http://www.troublefreepool.com/turni...sis-t4147.html
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,046
    Welcome!
    First step: fill out your signature so we know where you are, what kind of pool and what kind of equipment you have. Does your equipment include a manual vacuum? A robotic cleaner? A proper test kit?
    Second step: get the water circulating. The pump doesn't shut off, right? It just loses prime?
    Third Step: read Pool School until you feel like this
    Jun 2012
    Howell, NJ
    977
    I'm not sure I understand why you want new water. Nothing happens to it. It has been around for millions of years, and will be around for millions of years to come.
    John
    7 year old ~13,500 gal 24' AGP with 1.5 hp Proline pump, 150 sqft Pleatco cartridge, filled with well water with pH of about 4.5.
    Wanda the Whale pool vacuum, home made heater, Taylor K-2006
    Cloudy Pool? 1) Order test kit. 2) Follow SLAM
    New to TFPC? Read Pool School a few times, then post questions. PoolMath will help with chemical additions.
    Feb 2008
    Denton, TX
    5,061
    Yes it can happen. Your pool can float if your water table is high. That is why we tell people that if your aren't certain about whether you have water table issues or not, you should drain the pool in stages.
    There is no need to replace water unless you have a high CYA level.
