Thread: High TA after adding Muriatic Acid?
    May 2013
    So Cal
    2
    Hi!
    I'm pretty new here, but have been reading a lot of great stuff on the site. After taking my water to get tested Friday, I was told my TA was pretty high at 180. I added 16oz of Muriatic Acid with the filter running for 4hours. 2 days later I got my water tested at the same place and my TA went up to 200. I asked the guy why the TA went up and he said I wasn't running the filter long enough. Can that be possible? Am I doing something wrong or is it possible the test on Friday was done incorrectly?
    Fridays Test Results
    FAC 5
    TAC 5
    CH 590
    CYA 100
    TA 200
    PH 8
    Thanks everyone!
    10,000 Gal, Plaster, Chlorine, AO Smith 2.0HP pump, Pentair 36Sq Ft DE filter.
    linen's Avatar
    Jul 2010
    Twin Cities, MN
    8,649
    Re: High TA after adding Muriatic Acid?
    Welcome to tfp, Plint
    Muriatic acid will lower TA not raise it. Yet another reason to not trust pool store advice (or their testing). Take a look at this pool school article on test kits: http://www.troublefreepool.com/pool-...kit_comparison
    TA testing accuracy is really only +/- 10% when it is over 100.
    If you added high TA fill water between that could also explain the difference.
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,023
    Welcome!
    It is probable - almost certain - that the pool store tests are wrong.
    May 2013
    So Cal
    2
    Thanks for the quick reply guys! Maybe I do need to invest in a better test kit for my own sanity.
