Thread: Pool heater problem
    Pool heater problem
    Guys,
    I have a Hayward H250 heater - 2 weeks old.
    Its reading ignition failure from today after it stopped working.
    I've tried over and over to reignite - no luck - just IF reading.
    Any ideas on how to restart these units?
    T
    13,000 Gal (Est.) 14x28 pool w liner
    Hayward salt system - Aqua rite low salt
    Hayward Pro Series Filter
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    18,995
    Re: Pool heater problem
    IF means Ignition Failure, according to the manual.
    Two weeks old - that's their problem, not yours! Don't touch anything! Page 39 says to check that the gas valve is on and then a bunch of technical checks. Resist the temptation to grab a screwdriver. Don't give them any excuse to void the warranty.
    When my heater acts up, I've never had to do anything more than kill the electrical at the circuit breaker for ten minutes, then turn it back on. Try that.
    my H250 heater had a fuse for a 110 and a 220 volt system...depending on your system, the right fuse has to be installed......if all is correct that way, get a tech on the phone to walk through the troubleshooting.....my heater was reliable for the first 3 years then the heat exchanger crapped out...I fixed it but Imy first heater lasted 10 years
