Thread: Leaks at hose adapter connections with skimmer and return
    Hello, I have an 18' above ground pool. I currently have two leaks that I cannot get to go away at the threaded connection between the skimmer and the hose adapter and between the return line and the hose adapter. I have tried adding a ton of teflon tape on the threads to stop leaks but it still leaks. I'm at a loss at what to do next. Is there something I can put on the threads of the pool hose adapter??? Last year I dealt with the leak because I didn't want to drain the pool and fix it but this year upon opening I tried adding tons of teflon tape to the connections thinking that was the problem. It did no good. Any suggestions? Sorry for such a dumb question but I can't take the issue anymore. I also tried changing the hose adapter connector and still no luck.
    High Rockies (8000ft). 6 IG spas (2 Outdoor 2700, 1900) (2 Indoor 2760, 2050) (2 Indoor Cold Plunges 375, 320), Pentair Cartridge filters all, Plaster, 2 yrs old. Chemtrol automation systems for chlorine/bromine injection.
    22,553
    Re: Leaks at hose adapter connections with skimmer and retur
    Have you tried teflon paste? There have been some post about using a few wraps of t-tape then some paste then a couple more wraps of t-tape.
    Have you checked the female fitting for hairline cracks?
    24' x 52" Round AGP. 2hp/hp SPL Power-Flo 2-speed pump. 200sqft Waterway Cartridge Filter. 45MHP2(3GPD) Stenner Peristaltic Pump
