Results 1 to 8 of 8
Thread: What To Do First?
    Mar 2011
    Grand Rapids, Michigan
    279
    What To Do First?
    Just opened. YEA! Here's my numbers from my TF100
    FC 5
    CC .5
    PH 7.4
    ALK 130
    CH 160
    CYA 40
    I plan on adding 192 oz of 12.5% bleach to get to a suggested 16ppm shock level to knock out my CC. This is my third year with you guys but I still need some hand holding! Should I get my CH up a bit even though I have a vinyl lined pool? What's your opinion on my ALK and should I try to inch that down before I raise the chlorine? Thanks all!
    17,500 gal. ABG Doughboy Pool
    1/2 HP Pump/150 sq.ft. Cartridge Filter
    TF100 Test Kit And Speedstir
    Feb 2008
    Denton, TX
    5,061
    Re: What To Do First?
    Excellent! Good on ya for getting a good kit.
    Is your water green or cloudy? If not, there is no reason for you to shock. Your TA will come down with acid additions. Just keep knocking your pH down to 7.2 with acid and eventually, your TA will settle in. Anyhoo, if your water looks good, go swimming.
    30,421
    +1 what 257 just said. CC's of .5 ppm is treated as if it is ZERO.
    Mar 2011
    279
    Water is crystal clear. (Thanks to TFP) Will re-visit the Pool Calculator for acid additions. The CC just bugs me though! Supossed to start storming & raining here for the next three days. Nice, huh? Would love to go swimming 257 but I live in Michigan--the water is still a bit chilly! Don't have the pleasure of all that Texas sun! Anyhoo, thanks all for the quick response. I just love this site.
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,023
    I show 0 CC only about 25% of the time. It's no big deal.
    Jun 2012
    Howell, NJ
    977
    No one commented about the CH, so I will take that question. No need to worry about it. For example, my pool is currently running about 30 CH.
    John
    7 year old ~13,500 gal 24' AGP with 1.5 hp Proline pump, 150 sqft Pleatco cartridge, filled with well water with pH of about 4.5.
    Wanda the Whale pool vacuum, home made heater, Taylor K-2006
    Cloudy Pool? 1) Order test kit. 2) Follow SLAM
    New to TFPC? Read Pool School a few times, then post questions. PoolMath will help with chemical additions.
    Mar 2011
    279
    Thanks JohnN. I kinda thought I was OK on the CH but I appreciate your assurance.
    Butterfly's Avatar
    South Carolina
    10,045
    Nice job DebbieO
    Post a pic for us
    You're done SLAMing when:
