hello, i think i need a little help because i thought i had a clue but the lady at the pool store just told me exactly the opposite of what i thought...
i have a 49,000 gallon pool with a swg. it was opened 3 weeks ago and it cleared up nicely but i have been trying to get all the levels right. this is basically where i am at and i am still working on raising the cya, which is about 40. FC is 8, CC is .5 (i know that should be 0 but i don't know how to achieve that exactly), pH is 7.6, TA is 90-100, can't tell for sure(is the test supposed to be red red or dark pink?) i do use the TF-100 to test. by the way i have been running my filter constantly since it opened.
i thought that since the FC was high i needed to lower the percentage on the swg because too much chloringe is being produced. it was set by the pool guy at opening to around 70 i think, but i lowered it to 45 a week or more ago. the pool chemistry lady said i need to shock the pool so i should set the swg to super chlorinate. i am sure i looked dumbfounded, because i thought that didn't make sense so i clearly don't understand something. but i re-read some things on TFP here and i don't get what i am missing...
i would very much appreciate it if someone could tell me if she is correct (or not) and why that is. is it because there is a small amount of CCs?
thank you, lee
thank you, lee
