Thread: Lowering TA
    Mar 2012
    London, ON CDN
    42
    Lowering TA
    Just wondering if you guys would lower TA when it reaches 130ppm? When I opened the pool this year my CYA was zero but my PH was also around 7.0 so is I raised the PH to 7.4 which counter acted the CYA addition. Doing so also pushed my TA to 130ppm. Just wondering what my limit for TA should be or if I should even be concerned with it right now. Water is clear and about 20 degrees celsius.
    FC 3
    CC 0
    PH 7.4
    CYA 30 slowing being raised to 40-50 pool is in directed sunlight for 12 hrs
    TA 130
    CH 115
    Thanks
    21K gal, Vinyl, 16X32, 3/4 HP Hayward Maxflo, Hayward Pro 24" Sand Filter
    Apollo Pools (Canadian Supplier for Taylor Kits) www.piscines-apollo.com
    BoDarville's Avatar
    Jun 2012
    DFW, Texas
    3,841
    Re: Lowering TA
    NWCanuck:
    TA is a measure of the water's ability to buffer pH changes. Low TA levels usually causes significant swings in pH values while high TA tends to result in pH values drifting up. Your pH number is fine. Therefore, if your pH is relatively stable, I would not fiddle with the TA.
    One other detail I noticed is that you are raising your CYA from the present 30 ppm to somewhere in the 40-50 range. Is the reason you are raising CYA because your chlorine consumption is high @ 30 ppm? If so, then that's a good reason. However, if your FC consumption is fine at 30 then I would leave CYA where it is, especially given your more northerly latitude. CYA is much easier to add if needed, but much more difficult to lower if the level gets too high.
    Mar 2012
    London, ON CDN
    42
    Re: Lowering TA
    Thanks for the quick reply. This is the second year I have had the pool and last year I ran around 30ppm CYA. I would average somewhere around 1.5 liters of 12% bleach a day. And maybe somewhere around 2 liters with heavy use. The 3kg container of stabilizer I bought treats 67000 litters but does not tell you where that will put you in ppm. My pool is about 79872 litters according to the pool calculator. So I added 3/4 of the container and I am adding the last 1/4 after waiting a week on the first dose. I test somewhere around or just under 30ppm CYA at this point so I would like to get between 30-40 or 40-50 to combat CYA loss due to backwashing and splash out.
    I did not want to add the whole container even though it says it treats up to 67000 liters because it gave no indication of the resulting ppm.
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,037
    Re: Lowering TA
    Quote Originally Posted by NWCanuck
    Poolcalculator can do the math for you. Upper right corner allows you to switch units from US to Imperial or that fiendish metric system. Plug in your numbers, set the target to whatever you want, and voila! Instant answer.
    Down near the bottom there's Effects of adding chemicals, which is where I figured that if you added 2.25 Kg of that 3 kg container, you're at 28. The whole 3 kg should put you at 38.
    Mar 2012
    London, ON CDN
    42
    Re: Lowering TA
    Thanks Richard, I didn't even notice that.
