Results 1 to 17 of 17
Thread: cloudy water
    cloudy water
    First time poster, though I have been reading and studying advice here for awhile so I appreciate everyone's comments.
    I have been struggling with water chemistry getting pool open this year, and now that I "think" i have it close I am still having issues with cloudy water and am at a bit of a loss. (recently added borates and at around 50ppm)
    FC - 4.0 (no CC)
    pH - 7.6
    TA - 70
    CH - 200 (came down from 280 while adjusting other components of chemistry)
    CYA - 90
    Appreciate any advice.
    24,000 gallon, IG, Plaster pool
    SWG, with Heyward C-900 cartridge filter
    1970s build pool, Dolphin pool cleaner
    Feb 2008
    Denton, TX
    5,061
    Re: cloudy water
    Welcome to TFP!
    I imagine that your FC is not quite enough to adequately sanitize your pool with that CYA of 90. I might suggest getting your CYA down a bit (suggest 60 to 80 with a SWCG), shock, let it filter, and see what happens
    30,421
    Re: cloudy water
    Cloudy water most always means the shock process. There is an article in Pool School. Adhere to it until your water is crystal clear.
    I would lower the CYA to 60 first, and turn the swg off so you can shock with liquid chlorine and monitor carefully the FC. It can't be done right with the SWG on.
    A pic of your water would be helpful.
    Re: cloudy water
    How has your filter pressure been behaving? Have you needed to backwash/clean the filter?
    Re: cloudy water
    Let me add a couple pieces of info based on the recommendations to make sure I give the proper background (can a picture later tonight);
    * the current chemistry is the result of some adjustments made over the last week - water got better, just not very clear i.e. the drain at the bottom of deep end is a fuzzy
    * the CYA is up based on a little over shoot, last week it was actually close to 0 (not sure if I can bring down without a big water change?)
    * given how cloudy the water was, i have been cleaning the filter once if not 2x per week, including Strip Kwik treatment in last week
    * pool has not been shocked
    * below is chemistry numbers - last weekend and this weekend
    FC - 4.2 to 4.0
    pH - 7.9 to 7.6
    TA - 140 to 70
    CH - 280 to 200
    CYA - 10 to 90
    Borate - 0 to 50
    again the clarity got better as the water chemistry changed as above
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,009
    Re: cloudy water
    If CYA is 90, FC needs to be all the way up to 23 to get ahead of the algae. You're waaaaayy to low. Even day-to-day, with crystal clear water, you'll need to maintain a minimum of 7. If you get a sudden warm spell, that cloudy pool's gonna become a green pool.
    Probably what happened is that you got some CYA in the pool, which allowed the FC to kill some algae before the sun got it. But as the CYA level kept rising, the FC started getting bound up and lost effectiveness, which stalled the clearing process. Do something quick, before you start sliding backwards.
    [center:7jo1dzy8][youtube:7jo1dzy8]uijLXS-IJZM[/youtube:7jo1dzy8][/center:7jo1dzy8]
    May 2013
    Long Island NY
    419
    Re: cloudy water
    Now that was funny right there with ole Barney
    19,000 gal - Vinyl IG - Sand filter -1.5hp. - Taylor k 2006 - Loop Loc cover
    Re: cloudy water
    i am taking barney's advice and shocking now (picture of water below)
    Jun 2012
    Howell, NJ
    977
    Re: cloudy water
    Do you have the correct test kit (see my signature)? It will be impossible to follow the shock process (also in my signature) without it.
    John
    7 year old ~13,500 gal 24' AGP with 1.5 hp Proline pump, 150 sqft Pleatco cartridge, filled with well water with pH of about 4.5.
    Wanda the Whale pool vacuum, home made heater, Taylor K-2006
    Cloudy Pool? 1) Order test kit. 2) Follow SLAM
    New to TFPC? Read Pool School a few times, then post questions. PoolMath will help with chemical additions.
    Re: cloudy water
    yes, have Taylor K-2006
    Jun 2012
    Howell, NJ
    977
    Re: cloudy water
    Sounds like you know what you are on your way to a clear pool.
    John
    Re: cloudy water
    thanks for all the advice, 2 days of shocking and it cleared it all up!!
    Butterfly's Avatar
    South Carolina
    10,045
    Re: cloudy water
    Quote Originally Posted by svenkj
    Have you passed all 3 criteria to be done shocking? See red lines in my sig.
    Also,
    You know we love pics!
    You're done SLAMing when:
    Re: cloudy water
    yep, all three are have passed (new photo below, not sure if you can tell but much clearer now)
    Jun 2012
    Howell, NJ
    977
    Re: cloudy water
    Come on, you gotta show us the whole pool! That one little section won't do it for us.
    John
    Re: cloudy water
    fair enough, better picture below...
    Re: cloudy water
