Thread: Question on rain and pH levels
    Molson's Avatar
    Apr 2008
    Midland, Ontario
    479
    My pool has been open since late April. No one has been in it yet, still waiting for it to warm up. Temp at ~74 now.
    I tested my water a few weeks ago and the pH was 7.5 . Bromine levels have been fine (Have brominator). I tested the pH a couple days ago and it was low, 7.1/7.2ish. We have had a lot of rain lately. Would that be the cause of the low pH? I try to get the cover off and vac at least once a week to keep it clean. I bought a box of borax, but I think I'll need 2 to get it back to 7.5 range.
    40 x 16 IG Vinyl. Goldline SWG
    160 Sq Ft Roof mounted solar array
    2014 Hydropool Serenity 5000 Hot Tub
    The Pool School- A great place to start
    Jason's Pool calculator
    Mar 2007
    Knippa, Texas
    289
    Rain does tend to be acidic, so that's certainly a possibility for the cause of your low pH. What are your other test levels? It would help to know the TA, especially. If your TA is low, you might want to use soda ash (washing soda) instead of borax. Some (not all) bromine sources are acidic and tend to cause depletion of the TA and subsequent dropping of the pH.
    I am curious; why bromine? (If you explained it in some other thread, just direct me there.
    ~Jules~
    My pool: INDOOR 13x27 rectangular fiberglass, built ~2001, BBB, TA-60 sand filter, Hayward two speed pump (1 hp/0.33 hp), 3/4 hp booster pump for solar heater
    Taylor K-2006 test
    Molson's Avatar
    Apr 2008
    Midland, Ontario
    479
    Its an easy answer. Bromine cause thats the way it was when I bought the house in November. :P
    TA last checked was 85. You're right, I should use some Washing soda instead.
