Results 1 to 8 of 8
Thread: hth stabilizer & conditioner? same as cya?
    We seem to have issues in this area, getting CYA as a product alone (wo anything else in)
    Does anyone know whether this can be used and how much to use how this is pkgd?
    It was from local Walmart
    hth Stabilizer & Conditioner
    Ingredients:
    cyanuric acid 108-80-5
    sulfuric acid 7664-93-9
    water 7732-18-5
    (this was taked off the label-husband and I were on the ph, I typed )
    Not sure what the sulfuric acid would do added in?
    anyone?
    "VegMaPa" in the Midwest - a "NEWBIE"-opened pool July 2012
    AG Silverstone 24' Round x 52" -13,500GAL VINYL -ABOVE GROUND
    ClearWater Cartridge Filter CW65XL100SDBH (or is it W90, W120?) -Vortex XL150S 1.5HP Pump
    Hayward LP Gas Heater H150 .....LOVE TFP, crystal clear pool going on our 4th year!
    38,537
    Re: hth stabilizer & conditioner? same as cya?
    Did it list the % of cyanuric acid? If above 95% that is the stuff.
    Use poolcalculator to know how much to add.
    Sulfuric acid will lower the PH a little. However, there is probably only a very very small percentage of sulfuric acid in there.
    thanks I am going to look myself, my husband didn't see the %'s. Interesting about the PH. I will keep that in mind.
    I was thinking since I am just opening-top still on, I might wait to get the pool balanced first before adding the CYA. At first was going to add everything at once since it wasn't going to be used till probably next week. Now I am rethinking that. Thinking it might affect getting the chlorine just right and possibly mess up the calculation of how much to add. Does t hat make sense?
    pwrstrk's Avatar
    Elverson Pa.
    4,758
    I would start getting the CYA in there now. It takes time to show up on a test, about a week.
    Jeff
    So I don't plug in any cya till it starts to register. Act as if there is none to get my proper bleach amts?
    pwrstrk's Avatar
    Elverson Pa.
    4,758
    No. Shoot for 30 to 40 ppm of cya and assume its there and use cya fc chart for your fc levels. Make sense?
    Jeff
    Makes sense Thanks!
    Husband came hm with the stuff. It says 96% cya. He didn't see the fine print earlier. Men
