Results 1 to 12 of 12
Thread: Murky Green Water/Sky High Chlorine
    Hi everyone,
    I opened my pool on Tuesday and the water was black. I did the usual winterizing of the pool and closed the pool properly at the end of last summer. Since Tuesday, I am having trouble with getting the pool cleared up. The pool is no longer black, more like a light green, and very cloudy. Here are my test results.
    CL/BR: Sky high, the color of the water in the test tube is orange, instead of yellow. Have not shocked the pool in two days.
    PH: 7.8
    Alkilinity: 90ppm
    Hardness: 300ppm
    CYA: 60ppm
    I am not exactly sure what to do from here due to the sky high levels of chlorine. I can smell the chlorine when I walk near the pool. I have not added any chemicals to the pool in two days. Any advice?
    Ryan
    16k, IG Plaster, 3 Hp Intelliflow Variable Speed, 420 sf Cartridge Filter, 1977, Pentair Legend Pool Cleaner, Attached Spa, Some crappy Teledyne Larrs Dinosaur Heater
    Mod Squad woodyp's Avatar
    Apr 2010
    East Texas
    9,600
    Re: Murky Green Water/Sky High Chlorine
    You are NOT smeeling FC -free chlorine, the GOOD stuff.
    You ARE smelling CC--combined chlorine, the BAD stuff-------mostly ammonia.
    Welcome to the forum! You have not properly shocked your pool. Read the PROCESS of shocking in pool school.
    linen's Avatar
    Jul 2010
    Twin Cities, MN
    8,649
    Welcome to tfp, hatsoff389
    OTO test showing orange means you are somewhere between 10 and 30 ppm Total chlorine (TC). Unfortunately, this is not accurate or selective enough to do the shocking process efficiently. Take a look at this pool school article on appropriate test kits that include the fas-dpd test that is accurate up to 50 ppm FC (free chlorine): http://www.troublefreepool.com/pool-...kit_comparison
    At 60 ppm cya, you need to keep your FC level at 18 ppm until you pass the three criteria in the shocking process: http://www.troublefreepool.com/pool-...king_your_pool
    Quote Originally Posted by woodyp
    Tons of good info in the pool school, but I have not read anything in pool school that helps with my current problem. I do see now that I did not shock the pool correct. With the free chlorine so high, should I just keep the filter running until the number comes down? Is there a way to lower the combined chlorine?
    linen's Avatar
    Jul 2010
    Twin Cities, MN
    8,649
    Quote Originally Posted by hatsoff389
    Then you haven't read enough
    You need to pass all three end of shocking criteria simultaneously (also in my sig) before you let your FC level drop.
    Until you can test for it, you will not know your CC level...again a proper test kit is required.
    Jun 2012
    Howell, NJ
    977
    The FC is not high, the CC is high. The way to lower CC is by following the shock process, which was posted above and is linked to in my signature. To properly follow the process, you will need a good test kit, also linked i my signature.
    John
    7 year old ~13,500 gal 24' AGP with 1.5 hp Proline pump, 150 sqft Pleatco cartridge, filled with well water with pH of about 4.5.
    Wanda the Whale pool vacuum, home made heater, Taylor K-2006
    Cloudy Pool? 1) Order test kit. 2) Follow SLAM
    New to TFPC? Read Pool School a few times, then post questions. PoolMath will help with chemical additions.
    linen's Avatar
    Jul 2010
    Twin Cities, MN
    8,649
    Just to get us all on the same page...I do not think we know what the CC level is and the FC could indeed be high. The op can only measure TC.
    Again, this points to needing a fas-dpd chlorine test (included in kits mentioned in the test kit link above) to be able to differentiate FC (free chlorine) from CC (combined chlorine).
    Regardless, the op need to do the shocking process.
    Jun 2012
    Howell, NJ
    977
    True, the FC could be high. I think everyone is saying the CC is high because of the chlorine smell. I should have worded that better. We can all agree that the FAS-DPD test is needed.
    John
    linen's Avatar
    Jul 2010
    Twin Cities, MN
    8,649
    Quote Originally Posted by JohnN
    Agreed
    Just guessing here, but I would not expect this to be an "ammonia CC" like woodyp suggested since the cya level is still high. My guess this is the normal 1-3 ppm CC that occurs while killing algae and much of the TC level is actually FC...we just don't know how much.
    Quote Originally Posted by linen
    Agreed
    Waiting for my new and improved test kit to come in the mail. Thanks for all the advice. The free chlorine is also high per the test strip I just used. I know you guys can't stand them, but the strips, and this other test kit I have is all I can use until I get my new kit. I did shock the pool again today, following the shocking process in pool school, so we will see what the pool looks like in the morning. Thanks again!
    linen's Avatar
    Jul 2010
    Twin Cities, MN
    8,649
    Which one did you get?
    K-2006
