Thread: New pool just got filled. Dichlor question
    Jun 2012
    Hudson Ohio
    47
    My husband of the year has our new 18 x 54 Sharkline Matrix pool up and running. I have been in charge of Pool school. Water truck showed up at 8 pm Friday night and filled the pool. I used the pool calculator and added 71 ounces of bleach so we could swim yesterday. We forgot to add the dichlor last night-only to be used for the next 4 days per pool school. I tested the chlorine and PH with my taylor K-1000-dailey test kit- and the results are spot on. Want to start adding the dichlor. How soon can we swim today after we add the dichlor?. I will update my signature and post the pictures of the pool construction. Love BBB
    18 x 54 Sharkline Matrix pool. 7800 gallons.
    Pentair Optiflo 1 1/2 HP 2 speed pump
    Pentair Clean and Clear 150 Sq Ft cartridge filter
    Hayward H100ID Heater. Purchased all from Poolsupplyworld. TF-100 TEST KIT
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,074
    Re: New pool just got filled. Dichlor question
    Use http://www.poolcalculator.com/, down near the bottom where it says Effects of adding chemicals. See what the dichlor will do to things. As long as the FC is below shock level, you can go swimming.
    Feb 2008
    Denton, TX
    5,061
    Wait about an hour after adding chemicals before you swim.
    30,432
    Very quickly. (give maybe about an hour, depending on how you add it) It will dilute and spread throughout the pool quickly...swimming/activity will help with that distribution.
    Nice work on calculating and understanding your dosages.
