Thread: Intellichlor SWG installation question?
    I am planning on adding IC 60 to my set up. I will have a new 2 speed motor, pool vacuum and no heater. Do I need check valve or vertical bypass? Thanks, Kris.
    12,750 IG plaster/pebble. 1 HP uprated Duraglass pump. Cartridge filter.
    Ksnewman's Avatar
    May 2012
    Middle Tennessee
    173
    Re: Intellichlor SWG installation question?
    The Intellichlor manual says to put a check valve between filter and Intellichlor. Our PB said they usually don't put one in but I have asked him to. I am not sure that it is important or not but just wanted to be sure I didn't have any warranty issues.
    18x36 kidney 20,000 gallons IG vinyl. Pentair Easy Touch 8 w/IntelliChlor IC40. Triton II TR100. Pentair Intellifllo Variable Speed. Waterfall/Jump Rock. 2 Pentair Intellibrite lights. TF-100 Test Kit. And a very happy husband who gets to play in the pool without having to take care of it.
    Check valves are very important with tablet feeders, not nearly as important with SWGs. Also, the closer the SWG is to the heater the more important a check valve is. If you have 5+ feet of pipe in-between I really wouldn't bother with a check valve.
    Do I understand correctly? If i do not have a heater nor tablet feeder I do not need check valve?
