Results 1 to 12 of 12
Thread: Ideas needed for walkway around vinyl above ground pool
    JulieLeo's Avatar
    May 2011
    Atlanta, GA
    90
    This is our 3rd year for our above ground Summer Escapes pool. Finally my husband sees we need a better walkway around the pool.
    Would like some ideas and pics if available best way to surround the pool with an economical walk way.
    Thanks for your ideas.
    Julie
    12'x36" / 2100 gal/ AG / Krystal Clear Model 603 filter cartridge pump ( cleans surprisingly well for a $35 pump!)
    poolnew-b's Avatar
    Jul 2010
    laconia, NH
    131
    Re: Ideas needed for walkway around vinyl above ground pool
    Some have built decking all around the base. If mud is an issue you could use mulch around the pool. I've seen users put black plastic edging all the way around the bottom of the pool to prevent the mulch from poking the liner. Any pics? That might help figure out a walkway.
    Intex Ultra frame 16x48
    Intex 1600GPH Sand Filter
    Taylor K-2005 test kit
    May 2013
    Littleton, NH
    22
    Pavers would look really nice but they can get pricey. You might consider some stone though like river pebbles they are bigger round stone so it won't hurt to walk on with bare feet. I'm thinking of doing this after I get my AGP up this year.
    Intex 18' X 48" Hard Plumbed running the 1800gph pump that came with it. Using BBB method
    pwrstrk's Avatar
    Elverson Pa.
    4,758
    Stepping stones with the river rock would look nice also.
    Just my 0.02.
    Jeff
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,000
    If you go with gravel or pavers, put down weed block first. You don't want to be down there on your knees pulling weeds and weed-whacking around the pool with loose gravel nearby sounds like a recipe for disaster.
    Apr 2013
    Buffalo, NY
    29
    Yesterday, in Big Lots, I saw interconnecting patio decking tiles. I think they are 12" square and come in a box of 6 or 10 each. IDK, I didn't REALLY look at them, because I couldn't see a price on them.
    JulieLeo's Avatar
    May 2011
    Atlanta, GA
    90
    OK --so here's a lame out of focus pic of the pool... DH INSISTED on placing garden plots right beside the pool but I cropped them out.
    Basically the pool has a very narrow walk way around it....maybe 2.5 feet of space. This pic shows the pool with no water in it...but we've since filled it and straightened the supports and all is well. Now just need the walkway. Last year, I begged for a walkway but he didn't want the expense. FINALLY he agreed this year we need walkway around the pool, only because it was hard for HIM to walk around the pool when I needed his help to add a outlet to the bottom of the pool liner (No he never helps with pool upkeep and doesn't want to learn how to either! Just me...ugh!)
    So now, don't laugh..... but, this is all I have to show at this time. Still could wring his neck for digging up the yard so close to the pool, but can't change that............... THIS YEAR anyway.
    Any suggestions are helpful. Thanks.
    SuzyAbbott's Avatar
    Dec 2011
    Hamilton, NJ
    127
    We have a 9x18 rectangular intex and we have a wood frame 16x30 and backfilled it with pea gravel and installed stepping stones. It's worked out really well for us, we have 2 pool bars along the sides and a deck at one end. We also have a set of hot tub steps on the filter side that makes it easier for us shorties to clean the pool. The pea gravel looks great and has worked out really well with stepping stones. Just don't do the gravel until the pools up and full and don't cram it up against the liner. Happy landscaping!
    24' Sharkline Matrix. Coral Reef Liner. Clearwater II Cartridge Filter. Saltron Retro Salt WaterGenerator. 4x20 Ecosaver Solar Panels, Rover Jr. robot vac. Fiberglass Steps and Lifesaver pool fence/gate.
    Previous pool: 9x18 intex with salt water generator and vinylworks 5x10 deck.
    Jul 2014
    yulee florida
    1
    Try Pallets. Found for free. Depending on size of path if walkway isn't as wide as a pallet cut them in half. Use slats from bottom to fill in gaps on top. Instant deck. Use scraps from your cut out wood pieces to fill in angles around the pool. Water seal them , stain them or them and you have a nice deck around pool made out of pallets. Its cheap looks nice . Lay weed fabrics or heavy plastic on ground under the pallets to prevent weed growth weed eating near your pool.
    AimeeH's Avatar
    Apr 2012
    Columbia SC
    1,869
    I don't have an AG pool so I'm not 100% sure about what you mean by a walkway around it. We just put this walkway TO our pool in. It was work but not pricey. It was done using quickrete and a mold. I made sure we put it in so hubby could just mow over it with the John Deere as we have 26+ acres and about 3-5 acres to keep mowed. I wanted it to be as maintenance free as possible (and as cheep as possible for our budget). The cobblestone mold is a fixed expense then it is just as many bags of quickrete as you need. Not expensive but labor intensive.
    Please excuse that the project isn't complete with sod or grass re growing yet.
    18*36*23 true "L" vinyl IG 29,000 gallons. SWG. TF-100 test kit.
    http://tftestkits.net/splash-page.html
    Jul 2014
    Oakbank, Canada
    389
    Very nice!
    Quote Originally Posted by AimeeH View Post
    Ultra 16', Intex Sand filter/pump combo, 8' x 20' solar panels, solar blanket w/roll tube, 1" extruded foam floor with Gorilla pad, Liquid chlorine and stabilizer.
    AimeeH's Avatar
    Apr 2012
    Columbia SC
    1,869
    Thanks DarrelB. You can find videos on how to do it on the quickrete website but don't be fooled it was major labor. It was NOT however expensive. And gras can grow between in those gaps and still have a walkway......just mow over it. I don't know about mowing around an AG pool....I'd be afraid of kicking up a stone or two which is why a walkway like that might work. Put the walk in and mow over it. Maybe some roundup from time to time closer to the pool?
