Thread: PSI rising, no flow from returns...
    May 2013
    New Jersey
    28
    We've been up and running for about a week, with a psi consistantly at 10 and all of the sudden today there was nothing coming from the returns and no suction into the skimmer from what I could see, and the psi was at 20. We could still see water moving into the clear part in the pump though. We have no idea where to begin with this issue, any advice? Thanks!
    31,500 gallon IG w/vinyl liner, Hayward Pro Series S-244T Sand Filter w/ 1hp Hayward pump
    TF-100 Test Kit
    30,415
    Re: PSI rising, no flow from returns...
    It sounds like your filter is dirty.
    May 2013
    New Jersey
    28
    Should we backwash then? We just put new sand in before running it a week ago, there has been alot of junk from the trees falling though!
    TF-100 Test Kit
    pwrstrk's Avatar
    Elverson Pa.
    4,758
    Won't hurt to backwash and see what happens.
    Jeff
    May 2009
    Youngsville NC
    395
    BTW - the recommendation is to backwash your filter when the pressure goes up 25% over normal. So, if your startup pressure was 10, then you should have backwashed it at 12.5 PSI.
    16x32 IG 19,000 gallons, Pentair 1.5 hp Energy Efficient Superflo pump (348024),vinyl liner, Chlorine dispenser, Hayward S-244T sand filter
