Results 1 to 8 of 8
Thread: Marillion Fan
    Marillion Fan's Avatar
    About a 1/2 hour from P.S.U.
    259
    Marillion Fan
    hello all just taking a break from opening day. yep just today and opened to the worlds biggest maple oak pine teapot in the world yea the cover leaks :P
    I live in central PA and I am a Fan of the best band in the world that nobody knows about MARILLION.
    Just signed up after being over at the Pool Solutions forum and seeing that everybody was moving thought I better in case I need help getting rid of my teapot
    18x33 15700 Gal Oval Above Ground
    Ranger Sand Filter w/Praher Multi Port Valve
    A.O. Smith 1.5 hp Pump
    Confer E9120 Steps
    BBB And Sparkling Clean.
    SeanB's Avatar
    Mar 2007
    Missouri City (suburb of Houston, TX)
    2,622
    Welcome to the site. I hope we can help you clear up that "tea pot."
    TFP Founder
    My Pool: 13K gal IG gunite with 7' spa, Pentair Cartridge Filter, Intellichlor IC40 SWG, Polaris 280 Cleaner, TF-100 Test Kit w/ salt test.
    Arizona
    924
    Hi! Nice to meet you. That's quite a pot of tea you've been brewing. The experts here will get you on the right track to fixing it up.
    Buggs
    14,000 gallon, in ground, plaster, free form, play pool.
    Sta-Rite Max-E-Glass with a 1.5 hp Emerson motor
    WaterCo Micron High Rate sand filter S750 490 lb, 4883 sq ft - using ZeoBest
    In floor Polaris cleaning system
    Blue Diamond robot for those after storm days when I can't wait overnight for the in floor to clean it.
    Welcome!
    I like Marillion too, though have not listened for ages!
    8200 gallon 20' x 48" round vinyl frame pool,
    Intex SWCG, 12" sand filter, 1600gph pump, TF100 test kit
    259
    Quote Originally Posted by The Mermaid Queen
    Welcome!
    its always nice to hear that someone else knows Marillion you should go check them out they just relased album #14 andwill have #15 next year
    Confer E9120 Steps
    I did not even know they were still around! My faves were Kayleigh and Incommunicado, from the only 2 albums I had recorded! I always wanted to name my daughter Kayleigh, but wanted it spelled with a C and the proper pronunciation, and, well, I named her Charlotte
    259
    The new singer is great and the music will cheer you up, calm you down, or just make you into a puddle of tears
    if you haven't heard them go to marillion.com and listen lots of samples to wet your taste.
    Confer E9120 Steps
    259
    Tea pot is all clean and sparkling again
    The last time I tried to clear my water with pool store chemicals it never did go away until I went with BBB then it took a week I must be getting better at this stuff less than a week this year 8)
    Confer E9120 Steps
