Results 1 to 8 of 8
Thread: Return Valves: laid in not installed now leaking due to gaps
    Oct 2012
    Houston TX 77064
    101
    Houston TX: Oct 2012 had my pool plastered (brought down to the cement, due to three layers), turned out perfect, beautiful, then a leak 1-2" a week, did the normal troubleshooting and then hired a pro cause I could not find it, neither could they. Then in January damaged an return eyeball re-adjusting, so called someone to install a new one (I know I could have done self, but it was cold outside). I am so glad I did hire a pro for this simple trick, cause when he took the plate off to reinstall a new one, he noticed that there was a gap between the return valve and the pipe it was suppose to be connected to (this is why no one could test the leak 2" deep in the neck and the vacuum hose goes down 4-6"). The installer asked if he could check the other returns, since he knew it was a new plaster job. Low and behold all of them had gaps from 1/4" to 1/2". He asked if he could put come grout in the gaps to test if that was in fact the issue - but very temporary. Well no leaks, until the grout started to degrade, now I am leaking again. The installer that troubleshot this told me that it is a common problem with plaster jobs, plasterers get tired, lazy, or just don't know or pay attention, but most of the time there is little to no detection. The only way to fix it is plaster the whole pool and install correctly; chip around the return valves and reinstall correctly (ahg, my new plaster); or if you convince the contractor to just plaster the gap and warrant that job that would be the most cost effective for the contractor and less mess for me.
    Here is my problem the original contractor, is telling me the plasterer will fix - but will not give me any details and this will be covered under the plasterers limited warranty. I explained to the contractor I signed a contract with you not the plaster that he needed to explain to me what the process would be and extend warranty to cover this one specific issue as it will leak again, maybe sooner than later, but it will.
    Have any of you all heard of or had an issue like this? if so, what advice would you give me, specifically - can I trust they will fix correctly for me; is this a problem I will be plagued with for years to come; and is this an industry ugly secret?
    UPDATE: 2013-0620: Plasterer (no contractor) showed up late in the afternoon - took a look at the inlet valves from pool side and said there was no problem - stated that my contractor called to stop leaks around the inlet valves. I had to explained to him the original issue (all of it) and sat outside with him and took out every inlet valve, plate and all, told him to stick in figures down about 2-3" and tell me what you felt. His eye went wide and he stated saying it was because my pool was old that this is normal after plastering and that I will need to replace the piping inside the side of the pool that hooks up to the inlet valve, not his fault, nothing he can do. I asked him about the other options I was given by the other plasterers that did all the troubleshooting for me (i.e. replaster, chip around the inlet valves and set correctly, or fill gaps) and if he was sure there was nothing he could do for me given that I know what the problem is and that the other plasterers would not do the work required due to my warranty. The plasterer proceeded to tell me that he could seal the gaps on all the inlet valves with a puddy/plaster mixture, but not covered under warranty, cause not his problem - don't use the pump for the remainder of the night and should work fine, no leaks after it hardens. He also popped out all the value directional inserts, he stated that the pipes and valves need to be flowing freely, so the pressure will not harm the valves and pipes anymore than already done. Well here I am, 2013-0625, no leaks - but not the outcome I would have expected - wanting it fixed differently - considering I have been trying to fix this since last October.
    QUESTION: he did a good job (from what I see and feel, I could not have done better for what was done) - is this an acceptable process to rectify this issue? temporarily or permanently?
    13200 gal, IG, plaster, built 1985, replastered 2012, Mytilus MA-90C cartridge filter, 2716 Blue Line In-ground Pump and Motor (1 HP), (manual clean/brush/test with Taylor K-2006, TFP since 2012) in Northwest Houston TX
    Jan 2012
    340
    Re: Return Valves: laid in not installed now leaking due to
    You probably aren't getting any details as to how the job will be performed because, more than likely, he doesn't know. He is a contractor that is hiring a sub to do work. Where I am, there are a few subcontractors that do that work for all the contractors in town. Prep/refinish work is a specialized task that you probably don't want your contractor to do for you. He's probably contacted his sub and they said yep we'll get it on the schedule to fix it. I'd let it play out. If he's done his homework picking subs then you should have no issues. I've had a couple situations where a finish had to be patched and you would never know where they were done unless you had seen the job originally.
    25K aggregate IG, Intellipro, FNS48, Polaris 360, PG2000 fiber optic light source
    Oct 2012
    Houston TX 77064
    101
    Wow that is reassuring. I do know for a fact that he is bring in the sub that originally installed (hence the warranty issue), which is why I was so worried. But I asked if I could watch the subs fix it , the contractor had no problem with that, but the sub did. But I'm good. Thank you so much for the input, makes me feel more informed.
    Jan 2012
    340
    They are on your property and you can do whatever you want while they are there. With that said, watch them through your window. Only ask questions if you see something that really concerns you. They are coming back and working for free to fix something that wasn't done correctly, so it's best to keep them happy. Offer them some water or gatorade and bring questions up casually and not accusatory. I hope they get it fixed for you. Is it a pebble finish or quartz?
    Feb 2011
    Petaluma, Ca
    665
    Quote Originally Posted by thepoolman
    As my pool was built I watched nearly the whole thing from poolside, no one seemed to mind, although they may have preferred me not to. It's just too interesting to not watch.
    DONE, 20 x 40, inground gunite, 30" raised bond beam with 3 12" sheer descents, 8' diving board, pentair 420 cartridge filter, vs-3050 pump, intellechlor ic-40, auto cvr, Tahoe blue pebble tech, 6ea 4' x 12.5' & 2ea 1' x 12.5' helicol solar panels, legend robotic cleaner.
    Oct 2012
    Houston TX 77064
    101
    Smooth White Quartz - got the least costly finish, but not the cheapest installation (wanted it done right) - they did a beautiful job. I have a feeling that this issue would have never been an issue, but I am such a stickler about water waste that I monitor that as much as the cleaning and chemical testing/treatment.
    Jan 2012
    340
    Well not having any dye in the Portland and no colored quartz will hopefully work to your advantage when they patch it.
    Oct 2012
    Houston TX 77064
    101
    this is exactly why I love posting to this site. You all have made me feel so much better and confident about this matter than I could have possibly done on my own. See I would have never thought about that. Thank you again Poolman. You all have a great, wet holiday.
