Thread: AquaCal heat pump error code
    New Jersey
    12
    Turned on heat pump this year to discover an error code flashing on the control panel screen. It read "dPc". The index on the front panel stated that dPc meant "suction probe circuit is shorted", the user manual stated it meant "thermostat probe (suction) is short circuited". Any ideas on how to correct this problem?
    21k gal, Inground vinyl, 1 1/2 HP Emerson pump, Micromatic 26" filter, Aquacal heat pump w/solar cover, Manta automatic pool cleaner
    New Jersey
    12
    Re: AquaCal heat pump error code
    Problem corrected. Turned out that the thermostat wires to the circuit board were shorting out. Replaced the wires and I'm back in business.
