Thread: Aqua Trol RJ not generating!
    Unit is about 4 yrs old. When I took the cell off and cleaned and stored it for the winter everything was working just fine..
    Hooked everything back up a few days ago and it hasn't worked since! The red no flow comes on when plugged in and blinks for about a minute and then goes off. The the green lite for generating comes on and goes off in about 15 seconds and then nothing. Shows 0 for salt level.
    Tried all the test from this site http://www.nuccibros.com/sec_0934drRb_d ... -Guide.pdf everything checked good until I reached step H. When I tested the DSP board I came up with a reading of 1.2
    Thanks for any help you may be able to provide
    Feb 2008
    Denton, TX
    5,061
    Re: Aqua Trol RJ not generating!
    Welcome to TFP!
    We have a good many Aqua-Trol users here so someone with knowledge of your system should be by soon to help you.
    Welcome to TFP!
    That sounds kind of like a loose connection between the cell and the control unit.
    Thanks for the welcome guys.
    Checked and rechecked the connection between the cell and control unit and it appears to seat properly!
