Thread: Bumping up CYA
    Jul 2012
    California Central Coast
    74
    Bumping up CYA
    A quick question: If your CYA is a bit low (20), is it feasible to bump it up by just starting to use dichlor for a bit until it comes back up? Or is it to hard to control the level this way?
    Test Kit: Taylor K-2006
    Pool:In ground/Pebble/16,000 gal/Cartridge Filter/Pool Built appr. 1995-2000
    38,285
    Re: Bumping up CYA
    Just use the calculator to tell you how much you can add to get the CYA rise you want, and then be sure not to use more.
    I have used trichlor tablets to do this.
    Posted from my Droid with Tapatalk ... sorry if my response is short
    Isaac-1's Avatar
    SW Louisiana
    6,711
    Re: Bumping up CYA
    Sure I typically use 1 pound bags of dichlor to bump up my CYA when it gets a little low, the 1.7 ppm CYA and 1.9 ppm FC boost it gives me allows me to stay within safe FC range. When I see I need to raise my CYA I just lay out X 1pound bags, use them whenever my FC might need a manual boost (pool party, etc.) and when there gone I test CYA again.
    Jul 2012
    74
    Re: Bumping up CYA
    Great. Thanks for the tips.
